Dually fender light replacement (on an '04)
Before I start,
Anyone have a link to instructions or pics on how to accomplish this? I see that there is a clip on the back from the parts fisch. Do I need to remove the fender liner to get them out? Trying to avoid the usual "Dang, shouldn't have done that!" Thanks '77 |
Best Method to Replace
Cut push pins and drop inner liner and replace - takes 15 minutes to do both.
I tried for 1 1/2 hours to try and remove and re-install on bulb to no avail. Was not able to get inner steel plate to "lock" in place without removing inner liner. After removal of light discover that I need the socket that holds the bulb and buld. Corrosion has eaten away the elements. Anywhere on-line to get this part? Dealer wants $15 for small plug and is a prepurchased part only. May call different dealer as well. May do LEDs if nothing else. |
Originally Posted by 77f250sc
(Post 9360589)
Dealer wants $15 for small plug and is a prepurchased part only. May call different dealer as well. May do LEDs if nothing else. Turns out I didn't really need the clip after all... I thought mine was missing on my new-to-me truck, but it had just slipped back and was still there hanging on the wiring. Oh well, now I have a replacement just in case. Installing was relatively easy for me since a bunch of the plastic clips had already come loose from the cover, so I could reach a hand back. Unfortuantely the loose cover meant water sprayed back onto the red one and now I discovered that it's socket is all corroded so I'll need to get a new one of those. Picked up some replacement plastic clips at the local auto store and good to go. By the way, those new retainer clips can be really tight to squeeze on so you might want to fuss with it a bit ahead of time and see if you can do it first before using it to clip the socket assembly into the dually fender. |
(Post 9355988)
Before I start,
Anyone have a link to instructions or pics on how to accomplish this? I see that there is a clip on the back from the parts fisch. Do I need to remove the fender liner to get them out? Trying to avoid the usual "Dang, shouldn't have done that!" Thanks '77 Should I put some sealant/glue to adhere the clip to the inside of the fender? Also trying to avoid "Dang I should have done that!" |
