oil life indicator
Hello,
I have 7,000 miles on my 2010 XLT and I recently did a system check on the speedometer. I was looking for oil life percent to be around 20-30% but all it showed was dashed lines. This is strange because I changed the oil at the dealership only about 4000 miles ago. The manual says 7500 miles between changes. Anyone else experience this from their system check? Also, I don't see any warning symbols or signs that would suggest an oil change is needed, unlike my odyssey which shows a yellow warning indicator when the oil is at 15% or lower. Dave |
did someone turn it off? here's what the owners manual says. Not sure if you can decrease the value enough to turn it off or not, but just maybe that's what happened
OIL LIFE This displays the remaining oil life. An oil change is required whenever indicated by the message center and according to the recommended maintenance schedule. USE ONLY RECOMMENDED ENGINE OILS. To reset the oil monitoring system to 100% after each oil change (approximately 7,500 miles [12,000 km] or 12 months) perform the following: 1. Press and release the SELECT/RESET stem to display “OIL LIFE XXX% HOLD RESET = NEW”. 2. Press and hold the SELECT/RESET stem for two seconds and release to reset the oil life to 100%. Note: To change oil life 100% miles value from 7,500 miles (12,000 km) or 12 months to another value, proceed to Step 3. 3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the SELECT/RESET stem to change the Oil Life Start Value. Each release and press will reduce the value by 10%. |
Originally Posted by awq134
(Post 9341975)
Originally Posted by davelim
(Post 9341515)
Hello,
Originally Posted by D8chumley
(Post 9342492)
Also, the windshield reminder sticker has an OCI for 3000 miles ???
The dealer didnt reset mine, either. I had to reset it. Im not quite sure of the purpose of this feature, anyway. I got my first oil change at 6,500miles and 6months of ownership. The reading from the dash said I had something like "20% oil life. oil ok.".
But the manual says change the oil every 7,500 miles OR 6 months, whichever comes first. If I had listened to this goofy gage, it wouldve not coincided with the manual (and my better judgment) |
Originally Posted by juneau76
(Post 9343924)
The dealer that I bought my truck from is telling me it's due at 3,000 miles, also. Unfortunately, they are 1.5 hours away so I will be doing it myself and not getting it for free.
(Post 9341975)
or 12 months to another value, proceed to Step 3. 3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the SELECT/RESET stem to change the Oil Life Start Value. Each release and press will reduce the value by 10%. For the single button version, when you hold the button waiting for it to reset to 100%, keep holding the stick when it changes (don't release). It will eventually start counting down in 10% decrements. When you see the value you want, release the button. (PS and off-topic... why does this forum's text editor insist on removing my whitespace (blank lines) I place in my reply for readability? Very annoying that I have to force them in with BR codes) |
(Post 9345113)
This is for your first change right?
(Post 9345113)
I'm going that route and might do a UOA since I have a few unused sample bottles left over.
