Great video, thanks for sharing.
Originally Posted by cummins cowboy
(Post 9317836)
it didn't look like you prefilled the oil filter, maybe you did, was the oil that came out of the truck really dark??
Originally Posted by Rutcutter
(Post 9317839)
Love the video's EpicCowlick ! I thought the drain plug was cool too! You should have filled the oil filter before installation though... LOL
Originally Posted by Troy Buenger
(Post 9317905)
Excellent Video and very informative... Noticed you used 5W-40 weight.
Originally Posted by Painted Horse
(Post 9318434)
You didn't show what it took to remove the old filter. I'm spoiled by how easy the filter was on the top of the 6.0. I need to go see what size of filter wrench I need to get the dirty filter off. Hope I still have some old filter wrenches around that will fit that size on this truck.
I use a 5 gallon bucket to catch my dirty oil. I buy oil and hydraulic fluid for my skid loaders and mini execavators in the 5 gallon buckets, So I've got old buckets around. They have a pour spout that makes it easy to dump the old oil at what ever recycling place I take it to. 13 quarts will only fill the 5 gallon bucket about 2/3rds full. Slide it out from under the truck and snap the lid back on. So whats next Epic, A video on changing the fuel filters?
Originally Posted by tolliewolly
(Post 9318548)
Was that metal filter the only oil filter for the 6.7?
I have a 6.0 and have that big top oil filter. I am getting ready to buy a new 2011
(Post 9319033)
Did you have any problem finding a filter? And was it reasonibly priced?
Ford 6.7 liter Powerstroke Turbo Diesel Truck Filters - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks |
epic, what other diesels have you had before, a diesel will soot the oil way more than a gas engine however, these newer engines especially my dodge puts a ton of soot into the oil, I could go and change the oil thats in there that has only about 2k miles on it, replace it all with new and it would still look like road tar.
let me put it this way, was the new oil really dark after you replaced it. as for filling the filter, it probably doesn't make a lot of difference but I feel it helps get the oil flowing through the system a second or two faster, which can't be a bad thing. |
Originally Posted by EpicCowlick
(Post 9319596)
Holy crap! Serious? Is there a second filter on these engines? Because I sure didn't change it.
The previous gen engines, the 6.0L and 6.4L had a cartridge-style filter on top of the engine. Was a real breeze to change without making a mess. This one looks easy to get to and change, but a bit messier than the outgoing design. |
(Post 9319596)
Holy crap! Serious? Is there a second filter on these engines? Because I sure didn't change it. |
Can anyone confirm that there isn't a second filter?
(Post 9320102)
... as for filling the filter, it probably doesn't make a lot of difference but I feel it helps get the oil flowing through the system a second or two faster, which can't be a bad thing.
Originally Posted by Crazy001
(Post 9320115)
This one looks easy to get to and change, but a bit messier than the outgoing design. Note to everyone: Don't drop it in the full catch-pan to try to avoid a little oil on your fingers. You'll end up with a big splash on the floor, your arm, your shirt and your face. Trust me, I know. |
(Post 9320384)
I don't see a way to get the filter off without dealing with a bunch of dripping oil. This upside down design definitely keeps the oil in the cartridge, which is good, but all of the oil in the piping above it comes out and over the filter as soon as you break the rubber seal. I'm definitely wearing gloves next time and I'm not going to doddle with it. The best way is to simply get after it and turn off the filter quickly.
On my 6.4L you simply loosen the cap on top of the engine, let the oil drain for a few seconds, pull the filter and cap upward, tip upside down, and carry away. Very easy to not spill even a drop of oil. But with any luck these oil filters will eventually be cheaper than the FL-2016 cartridge filters used in the outgoing engines. Never could get one cheaper than $18 at wal-mart! |
Originally Posted by GMUGNIER
(Post 9320317)
A little trick that I learned is to take an old screwdriver and sharpen it to a point and use this to puncture the bottom of the filter. It takes a little longer do drain the filter but at least you know where the oil is going.
Originally Posted by JReinert
(Post 9320975)
There is no second oil filter. I was just wondering if the one he changed was the oil filter. It looked kinda small. The 6.0 oil filter is alot bigger than that oil filter he changed for the 6.7
Laughter makes the world go round....
That's all I got,
We do appreciate your efforts! Newbie here, going back quiet. Oh, did I mention I'm a previous Dodge guy? Oops, I gues I've arrived at the bright side.:-jammin:-missingt |
(Post 9321824)
I just copied this from the diesel supplement:
To change the engine oil and oil filter: Obviously says nothing about pre-filling the filter which makes me feel better. Is this practice common in dealerhsips or at Ford? Or is this something that is just a good idea perpetuated in the forums? I wonder if the factory pre-fills the filters when they install the engine on the truck for the first time.1. Unscrew the oil filter and oil pan drain plug and wait for the oil to drain. Note: The oil pan drain plug only requires 1/4 turn to removal/install. A 3/8 inch socket drive may be used to assist with removal/installation, but be careful not to over-tighten the plug during installation. 2. Replace the filter. 3. Reinstall the oil pan drain plug. 4. Refill the engine with new oil. For the proper capacity, see Maintenance product specifications and capacities in this chapter. 5. Reset the Intelligent Oil Life Monitor™. See Message center in the Instrument Cluster chapter for more information. |
