Fuel tank capacity question
Hello all, I have a 2011 F250 (6.7). I am perplexed by the fuel tank capacity. I recently had a low fuel light with the trip computer telling md 44 miles to empty. When I filled up the tank only took 21 gallons. I thought my F250 had a 30 gallon tank. Am I missing something here? It doesn't ad up. Thanks in advance for the input.
I believe you may have a 26 gallon tank. I assume the additional room in the normal gas tank area (where the 30 gallon tank used to be) is for the DEF tank but I have not seen the underside directly.
From the Ford 2011 Super Duty 4/01/10 order guide: "Major Product Changes" under "packages": - Pickup Fuel Tanks vary by Engine and Wheelbase
If you have a short bed your tank is 26 gallons. Long bed (8') tank is 37.5 gallons.
