2009 E350 bolt pattern
Is it true that the bolt pattern on the E-series vans (2009) are not the same as the regular 8 lug super duty's. I was told there were but what I have found on the internet says a little different. The bolt patterns are 8x6.5 and not 8x170mm...any info would be great.....
The lugnuts appear to be fractional. Whereas the Truck (99+) is metric. This plus any research you've I'd tend to believe they use the old 62+ bolt pattern.
