no drain plug on my torque converter?
Did a trans flush this past weekend, drained the pan, replaced filter, moved on to draining the torque converter, I spun the crank many times and I dont seem to have a drain plug for it? Had my son look with a flashlight while I spun the crank over and same results? Anyone else have no drain plug? How do I perform a complete flush?
2003 Expeditioin EB 2WD 4R70W transmission |
This thread should help with the 'how to'...
https://www.ford-trucks.com/forums/9...xperience.html |
Just found out that starting in 2001 Ford eliminated the drain plug on the torque converters, therefore the only way is removing the oil cooler hose method
