BEST YEAR FOR 5.4 DOHC MOTORS
What year or years is best for the 5.4 dohc lincoln navi motors? Also wondering what the trq/hp numbers are?
thanks. |
any one you can get cheap !!!!!!!!!!!!!!!!!!!!!!!!!:-missingt
I think certain years are the best for hp/trq like early 2000's. 1999-2003 I am thinking, but not sure.
Thanks. |
i would say the later models have more power
From Wikipedia
Vehicles equipped with the 32-valve DOHC 5.4 L include the following: * 1999–2004 Lincoln Navigator, 4-valve DOHC, 300 hp (224 kW) and 355 lb·ft (481 N·m) * 2000 Ford Mustang SVT Cobra R, 4-valve DOHC, 385 hp (287 kW) and 385 lb·ft (522 N·m) * 2002–2005 Ford Falcon XR8, 4-valve DOHC, 349 hp (260 kW) and 369 lb·ft (500 N·m) * 2005–2006 Ford GT, 4-valve DOHC, Aluminum block, Supercharged, 550 hp (410 kW) and 500 lb·ft (678 N·m) * 2006 Ford Falcon FPV GT, 4-valve DOHC, 389 hp (290 kW) and 384 lb·ft (521 N·m) * 2007–2009 Ford Shelby GT500, 4-valve DOHC, Supercharged, 500 hp (373 kW) and 480 lb·ft (651 N·m) SAE J1349 certified * 2007 Ford Falcon FPV GT Cobra, 4-valve DOHC, 405 hp (302 kW) and 398 lb·ft (540 N·m) * 2008 Ford Falcon FPV GT, 4-valve DOHC, 422 hp (315 kW) and 406.5 lb·ft (551 N·m) * 2010 Ford Shelby GT500, 4-valve DOHC, Supercharged, 540 hp (403 kW) and 510 lb·ft (691 N·m) * 2011 Ford Shelby GT500, 4-valve DOHC, Aluminum block, Supercharged, 550 hp (410 kW) and 510 lb·ft (691 N·m) |
Depending on what you want to put it in I'd suggest looking into DOHC 4.6L's, the Navi engine had a pathetic torque curve considering they are in a truck chassis. AFAIK there were no differences between the different model years, but if Ford did discover a problem early on they would have fixed it by '03 or '04.
