Need Part Help - Rubber stoppers... Killing me...
I have an '03 Excursion V-10 4wd.
I try to search before asking for someone else to help with my dirty work, but I absolutley can't find part numbers for these annoying items. I have had the dealer try and he orders me parts that I don't even think have a home on the excursion. The first is (are) those big rubber door stops. They area about an inch long and pop in to the actual door. I think they are called "rubber door stops" and I saw a suggestion that they may be: PN W705903S300 - For the xpedition and F-150 The second are similar, but the small rubber stops on the bottom of the liftgate where it touches the barn-doors. I have no idea what those are called and cant track them down. Any help would be appreciated. If this is a common question, I apologize. I don't know what the heck they're called so I'm not sure I'm searching with the right terms. Thanks. |
https://www.ford-trucks.com/forums/7...mberdummy.html
Dont know about the rears. |
You could go to Uhaul that has Ford cab trucks and.......
Or you could just do the 3/8 inch tubing in the weatherstripping to stop the rattle. |
Thanks
I'll jump on those for the doors.
any advice on the small rubber stops on the rear hatch? I do appreciate the help. |
anyone ever come up with the parts number for the rubber stroppers on hatch or a good replacement?
The large door bumpers for the 4 regular doors are : YC3Z-2525076-AA. They come in a package of 3.
The rear driver and passenger regular doors also have smaller bumpers mounted on top of inside door..those are part # 374217s . With a little trimming they might also work for the barn door/hatch bumpers. But below is correct part #'s: The 2 small bumpers for the rear hatch where it contacts the barn doors are part # N805307S. They are discontinued, but i found some old stock through google etc. One to a package, so you need two. Use a dab of silicone when installing to ensure they don't fall out again. |
