second row seat locked down
my second row bench seat wont return to the up position. Looks like the latch is hanging up when I compare from seat to seat in that row. any suggestions
Move both front seats forward to let pressure off of the second row. This happened to me when I first got mine.
Originally Posted by angelsndevils
(Post 9072214)
Put a small amount of silicone based lube release gears if it feels like it's hanging up. I always have to move them around a bit to get mine to release also. But is easier with a small amount of lube.
Are both seats designed to slide forward or just the smaller one?
Pull up on the black side lever and force them up. They will come.
Originally Posted by mark996
(Post 9072924)
both should slide forward. |
Were you ever able to get the seats up? What did you have to do?
Originally Posted by joenmell
(Post 9074760)
Thanks for the info. Keep us informed if this could be a ongoing problem.
My seat was stuck, the 60 side, so I pulled it forward and pushed pretty hard on it, it sprung forward, I greased it, works wonderfully now, greased the other side while I was at it.
