Thanks Bill (NumberDummy) for your help it is very much appreciated, on to next list.. lol
steve |
After reading all the postings here and elsewhere on the web I guess that only the experts here can decode this VIN.
I'm buying a 1977 Ford Armored Truck VIN "D0532GHB22243" which stumps me. Dunno what the door plate says but received a photo confirming this VIN from a lable somewhere. Thanks in advance, looking to build the ultimate Zombie Apocalypse vehicle... |
2 Attachment(s)
Originally Posted by CurlySurmudgeon
(Post 15032286)
I'm buying a 1977 Ford Armored Truck VIN "D0532GHB22243" which stumps me. Dunno what the door plate says but received a photo confirming this VIN from a lable somewhere. Thanks in advance, looking to build the ultimate Zombie Apocalypse vehicle... The armored trucks from this era that I'm familiar with...were either F350/750 Cab & Chassis or E350 Cut-Away's. None of these came with "back of cab" equipment. The aftermarket bodies were installed behind the cabs on their bare frame rails. 1963/79 trucks have a Warranty Plate located on the left door face below the latch with the VIN and other codes stamped on it. 1970/79 trucks have a Safety Standard Certification Label glued to the B pillar below the striker plate. The production date is printed on the upper left hand corner, the VIN and GVWR's are also printed on this label...and that's about it. But, these trucks were not titled or registered by these VIN's, as they were too EZ to change. Trucks were registered by the hidden VIN stamped on the frame rail. So, what this armored truck could be...is a rolling chassis from another make of truck with the 1977 Ford body mounted to it. This occurred somewhat frequently with commercial vehicles. Examples of the 1973/79 Warranty Plate (left) & the 1973/77 Certification Label (right) from the 1973/79 Ford Heavy Truck Parts Catalog: |
Hello, I also need help decoding a vin as well. Just bought the truck today.
Vin# F70DUC59735. |
I have one. I am purchasing a 1958 F600, but want to know more about its history.
The VIN is F60C8K32223. The date is 11C. Axle is 53 and the color is S. I have figured some of it out but other things such as the color elude me. Any help would be great. |
Originally Posted by meyers_3521
(Post 15137170)
Vin# F70DUC59735. D = 330 2V Heavy Duty FT engine. U = Louisville KY Assembly Plant. C59735 = 1968 (per your other thread that ID's it as such). Otherwise it could also be a 1976. |
Originally Posted by kylebailey
(Post 15138514)
The VIN is F60C8K32223. The date is 11C. Axle is 53 and the color is S C = 292 2V 8 = 1958. K = Kansas City MO Assembly Plant. 32223 = 1958 Numerical Sequence of Assembly. 11C = Assembled March (C) 11, 1958. 53 = Eaton Two Speed Rear Axle / 5.83/8.11 / 15,000 lbs. Rear Axle Capacity. S = Special order non standard color. |
Thank you sir. Does that VIN tell a guy about the original transmission?
I appreciate your legwork and will post pics of this beast when I figure out how. The special color makes sense as you can see this "yellow" paperweight coming for miles. :-X22 |
No TRANS code is within the VIN of any FoMoCo vehicle. Listed separately on the Rating/Warranty Plate.
Roger that. Thanks.
1975 L800(?)
My VIN is L80F1X07884, Color:GC, Type: L809, Body:4A8, Trans: O, Axle:KFR. Thanks in advance!
vin decoding
hi, my vin # is N70EVW46395 I was hoping some one can tell me what type of engine type it should have... or it has... i know its gas, and thats about it. also, i'm looking for a clutch kit... hopefully cheaper than napa auto parts... any help is greatly appreciated.
can some one please help me with decoding my vin: n70evw46395. thanks in advance...
Help with vin decode
F60MK614418
MODEL F602 BODY 481 TRANS F8 thank you in advance |
Please help me with years, engine size, etc on the following two serial numbers.
D70BVCA8358, and C55CVA71354 Thanks. |
