Originally Posted by RedStroke
(Post 13587324)
W.B. 146 / COLOR: A / MODEL: F611 / BODY: DB8 / TRANS: A / AXLE: F33 / MAX GVWR LBS: 20200 / DSO: 43
A = Raven Black. F611= F600 2WD (gas), 20,200 lbs. GVWR DB8: DB = Black Vinyl (Heavy Duty) / 8 = 81B Custom Cab. A = New Process 435 4 Speed Manual Transmission. F33: F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity // 3 = Ford 6,000 lb. Capacity Front Axle. 20,200 lbs. Gross Vehicle Weight Rating. 43 = Milwaukee WI Ford District Sales Office, where the original selling dealer ordered the truck from. |
Vin Problem
Trying to buy this truck with vin 1FDTK74N9FVA15254 HELP
Originally Posted by w6qwa
(Post 13645969)
Trying to buy this truck with VIN 1FDTK74N9FVA15254
IFD = FoMoCo USA - Ford Truck - Incomplete Vehicle. T = Air Brakes ~ Class 3 - 10,000-14,000 lbs. GVWR K74 = F700 Diesel Conventional Cab. N = Detroit DDA 990 N or 990T 8.2L (501 cid) V8 diesel. 9 = Check digit, FoMoCo internal use only. F = 1985. V = Kentucky Truck Assembly Plant. A15254 = 1985 Numerical Sequence of Assembly. |
vin F70EUD97958
Vin decode help
I need some help decoding a vin on an f 700 it is f70evu11820 any help would be greatly appreciated fairly new to the site
VIN Decode
I need some help with the VIN number from my F 700, could anyone help please?
VIN: F70EVA87796 WB: 176 Color: TT Type GVW: F702 Body: 416 Trans: 0 Axle: 553 Max. GVW: 22000 D.S.O. : 99 Thanks in advance |
Need some hep in decoding a VIN
I just bought a project truck its VIN is N70EVB12528
202 wheelBase JT color n702 type/GVW 8A8 body M trans 55 54M axle 23,000 MGV Lbs --- reading through the previous posts and decoding, I think its a 1976 F-700 w/361 2V 5 spd and 2 spd alxe, red out and red in But what is the N70 mean? Thanks for all your time and help stevenh |
Originally Posted by Shade Tree Mech
(Post 14862442)
202 wheelBase JT color n702 type/GVW 8A8 body M trans 55 54M axle 23,000 MGV Lbs --- reading through the previous posts and decoding, I think its a 1976 F-700 w/361 2V 5 spd and 2 spd alxe, red out and red in But what is the N70 mean? Thanks for all your time and help stevenh http://www.curbsideclassic.com/wp-co...nseriescab.png |
Thanks for the quick reply, I now have some more questions. I think I will buy the Ford book to have on hand.
New guy question
I tried looking around before asking but it just made me more confused so I'll just tell you my problem. I bought a 75 F100 4x4 last year and have slowly been working on it. The VIN is F10GRV60117. Now from what I have read in this forum is that this truck is a 2 wheel drive (F10), however it is a 4x4.:confused: The Dana 44 front axle does not look to have been added but looks original to the truck. I was thinking, could the previous owner have swapped doors, since that is where the VIN plate is?:-huh I've looked for the frame VIN but haven't located it yet.:-X18 Any help would be much appreciated!
Originally Posted by Bubblegum0321
(Post 14878400)
The VIN is F10GRV60117 Now from what I have read in this forum is that this truck is a 2 wheel drive (F10), however it is a 4x4.:confused: The Dana 44 front axle does not look to have been added but looks original to the truck. I was thinking, could the previous owner have swapped doors, since that is where the Warranty Plate is located. I've looked for the frame VIN but haven't located it yet. G = 302 2V (excepting 1969/77 Bronco's, 302 not available with 4WD until 1980). R = San Jose CA Assembly Plant. V60117 = 1975. Compare the VIN stamped on the Warranty Plate to the VIN on the registration/title to see if they match. People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors. Doors same: 1973/79 F100/350 & 1978/79 Bronco. |
(Post 14862442)
N70 = LN700 (gas) / E = 361 2V or 4V / V = Kentucky Truck Assembly Plant / B12528 = 1976. W.B. 202 COLOR JT: J = Rangoon Red / T = Candyapple Red TYPE/GVW: N702 = LN700 (gas), 23,000 lbs. Gross Vehicle Weight Rating. BODY 8A8: TRANS: M = Clark model 285V 5 Speed Direct. AXLE 54M: 54 = Rockwell/Timken Single Speed Rear Axle / 6.83-1 / 17,500 lbs. Rear Axle Capacity // M = Ford 7,000 lbs. capacity front axle with P/S. GVWR = 23,000 lbs. It's a 1976 LN700 w/361 2V 5 spd and 2 spd :-huh axle This has to be a 1976, as TYPE/GVW was not used on N700's, MODEL code was used instead. |
Just upgraded my dump truck. I was told it was a garbage truck and was converted to a dump truck. Any more info is appreciated. Thanks Adam
VIN 1FDNF80C4WVA17033 Type GVW F80260 Body 8 Trans AA RC 48 |
(Post 14884882)
VIN 1FDNF80C4WVA17033 / Type GVW F80260 :-huh / Body 8 :-huh / Trans AA / RC 48 :-huh IFD = FoMoCo USA - Ford Truck - Incomplete Vehicle (Cab & Chassis). N = Class 6 Hydraulic Brakes, 19,501-26,000 lbs. Gross Vehicle Weight Rating. F80 = F800 Diesel Cab & Chassis. C = Cummins 5.9L (359 cid) 6 Cylinder Diesel. 4 = Check digit, FoMoCo use only. W = 1998. V = Kentucky Truck Assembly Plant. A17033 = 1998 Numerical Sequence of Assembly. Most of the following codes are incomplete and/or were copied down incorrectly. Type/GVW: F80260 = 60 doesn't belong, should just be F802, but F802 is not listed in the parts catalog. BODY: 8 = You're missing at least one digit. AA = Allison model AT-545 Automatic Transmission. RC 48 = I have no idea what RC refers to, nothing like this is listed in the catalog. |
Thanks for the help Bill. I believe the last 3 digits of the F80260 are the GVW. I saw another 30,000 gvw and its tag said F80300
See tag below. https://cimg5.ibsrv.net/gimg/www.for...1a150753b2.jpg https://cimg8.ibsrv.net/gimg/www.for...8aac43f67d.jpg |
