Oil residue on filter..
Hey guys I have noticed oil residue on the side of the oil filter. I had changed my oil about 2000 miles ago and had noticed the residue so I cleaned it off and figured I just didnt clean it that great when I finished changing the oil. I just looked under there again and noticed that the oil is back again. I have done plenty of oil changes on diesels before and never has this happened. I made sure the old filter ring was not stuck to the housing. And I made sure to oil the new seal and clean the housing. Is this normal on the 7.3?
-AJ |
Not normal.
You have a leak somewhere. |
I have the same problem. I very slight leak that runs down the side of the filter. Have gone through 4 filters since I have had the truck and they have all done it. I just live with it.
Originally Posted by Kwikkordead
(Post 9029051)
Not normal.
Originally Posted by ChunderDownUnder
(Post 9029053)
I checked if the filter came loose but it was tight and I ran it for a while then checked again and the residue came back. Ill just deal with it for now. |
I met up with a bloke who had a 05 (we got em to 06) and he's did the exact same. I dont know if it is the same over there but there is a yellow dot on the oil filter housing on ours just were the filter buts up and thats the exact same place on both of ours where it weeps. the only option I see with my problem is to replace the filter housing or take it off and get it re machined. But as I said its only a slight weep and I really cant justify the cost.
