Question about taping for boost gauge.
I have an Autometer boost gauge 4305. And I know I need to install in into the pipe going into the intake.
My question is, what size hole do I need to drill? and what size tap is needed? Is it a NPT tap? I am clueless on this I have never taped anything before. I do have a set of metric and SAE tap and die sets but I don't think they will work. Thanks in advance for the help. |
most are 1/8" npt but check the transducer that came with your gauge to be sure.
Originally Posted by hndacr
(Post 9025642)
So do I need an 1/8" drill bit and 1/8 NPT tap? |
You need an 1/8 NPT tap but the drill size is difference. The drill size should be listed on the tap. DO NOT GO BIGGER on the drill size or you won't have enough threads to hold the fitting in the elbow, which is only pot metal and fairly soft. Give me a few minutes and I'll go look in my set to find the correct size for you.
Wouldn't you know it??? All my taps list a drill size EXCEPT the 1/8 pipe, which is NOT 1/8" |
Originally Posted by npccpartsman
(Post 9025656)
You need an 1/8" NPT tap but the drill size is difference. The drill size should be listed on the tap. DO NOT GO BIGGER on the drill size or you won't have enough threads to hold the fitting in the elbow, which is only pot metal and fairly soft. Give me a few minutes and I'll go look in my set to find the correct size for you.
Originally Posted by 02GrayPowerStroke
(Post 9025663)
Thanks! Where can I get the tap? Lowes or an autoparts store?
1/8 pipe thread drill size 5/16 decimal .3125 hope this helps.:-wink
Originally Posted by John Diem
(Post 9025812)
Is it going to be 1/8"-27 NPT tap?
(Post 9025812)
(Post 9025921)
Cool thanks
Best remove the tube before drilling and/or taping. Don't want metal shavings in your engine.
(Post 9025933)
Cool thanks
DSMMH |
Originally Posted by DSMMH
(Post 9026118)
If you have an '04 you probably have the dummy butterfly thingy between inlet elbow and the manifold. It is the thingy that has two electrical connectors attached that do nothing. Instead of drilling the elbow you might want to consider drilling the dummy butterfly thingy. If I remember right, it is square, not round like the inlet. Just food for thought.
DSMMH BTW Went at lunch and got what I needed at Lowes. |
