having to pump the gas pedal when starting???
Hey guys I got a 88 7.3L n when I start it I have to pump the gas pedal constantly till it starts or else it wont start n just kill my battery. Help please!!
from what they tell me, pumping the go pedal on these things does nothing..........that being said, I usually hold mine down about half way when starting. seems to start faster that way..........
I turn the key on, hit the pedal one time to set the high idle, wait for WTS and start, no problems even in low negative weather, holding the pedal half way down only shortens the life of the motor.
I would say you have air intrusion and pumping the pedal makes you feel good. Tomorrow morning (or after it's been setting 12 hours or so), Pull the fuel filter and see if it's completely full of fuel, if not install a Injector Installation Kit. -Enjoy fh : )_~ |
ip maybe does it want to cut out after it gets going at all or idle rough if not then im with festus on it
Originally Posted by 94 smokin stroker
(Post 9015198)
Originally Posted by Festus Hagen
(Post 9015138)
these rigs are not carbureted,so pumping the skinny isn't going to send any more fuel.you can pump the peddle if you want for the exercise lol.
you need to check for air intrusion,and test the glow plug system,along with first inspecting the starting system;cables/terminals/batteries/stater etc. did you check the top threads yet Kurt about testing GP's etc? having a full set of 8 working Beru's is a must. |
No I haven't checked the glow plugs yet don't know how (first diesel). Want to replace them but can't find the motorcraft ones cheaper the 40$ per glow plug.
I know that I only paid $11 apice for mine at th elocal Kentucky motors parts store. I use the 7.3 gp's. Make sure that the guy you are talking to knows it is an IDI and not a stroke.
Also there is a thread at he top of this forum page that has the procedure for checking the glow plugs. Give it a read and it should get you through it wth no problems. If you run into a snag just ask and some one will help ge tyou thruogh it.
How much faster does it start with pumping the pedal? Pushing the pedal down will give more fule during cranking if the IP is pumping fule and not air and also will help get air out faster. The reson the manual tells you to hold it half way cold all the way below 0 is to advance the timming. Also how does it start when the engine is warm? Festus how do you figure holding the pedal down hurts the engine?
kenpobuck
ill check that out n im pretty sure he knows its an idi. old ford dealer coworker. George D. in my truck it says above 32 half throttle below 32 full throttle. id say about 15-20sec differince |
Ah ok, you checked througth the stealership lol. I would do a search online for them. Make sure they are motorcraft/beru though and not the others. Most guys on here will tell you it pays in the long run to use them.
ok does it still take to long when you pump it?
Diesel Filters Online - ZD9 Glow Plugs $9.99
*** Glow Plug Test. *** Test light test of the glow plugs:
-Enjoy fh : )_~ |
