7.3 Powerstroke fully built race long block
Up for sale is a fully built long block engine for any year 7.3 powerstroke. I built this last summer and have only about 8000 miles on it. Intended to push my truck into the 11's and some lifestyle changes have came and now i am selling all my go fast parts. Here are the mods:
Hardblok filled water jackets to 2" from deck surface fire ring grooves cut in the block main girdle and studs by Wide Open Crower connecting rods Mahle pistons .030" lowered to 15:1 by bowl work, teflon and ceramic coated, total seal rings Polydyn coated main and rod bearings Balanced rotating assembly WOP fire ring headgaskets Melling oil pump ATI harmonic damper (its off right now, being rebuilt at ATI) Ported heads (i spent several several hours on these) with inconel exhaust valves, bronze guides, valve job and some crazy stiff ~145lb seat pressure springs Smith bros pushrods H-11 head studs Beans billet intake plenums ATS billet flexplate Powdercoated valve covers, new gaskets Small things such as welded cam gear, welded oil jets, welded and circumsized oil pickup tube Line x oil pan |
interested in the long block
Im interested in the long block, where are you located? thx mike
