Door Lock Tumbler Assembly
OK guys bare with me this is my first post. The other day my driver side door lock quit turning so I went out and bought a new one. I know i could have just shot some lube or something in there but i was concerned about the ware on my key. Didn't now if any of the tumblers were worn out or not. This is the way i went about it.
First i removed the inner door panel. https://www.ford-trucks.com/user_gal...id=233688&.jpg Then the little black plug. https://www.ford-trucks.com/user_gal...id=233689&.jpg Witch reveled one of the door handle nuts. Remove this nut (11mm 1/4" drive socket) https://www.ford-trucks.com/user_gal...id=233691&.jpg down and to the right is the other nut tucked in behind the window track. remove this nut (11mm wrench) https://www.ford-trucks.com/user_gal...id=233700&.jpg Door handle removed reveling lever rods. https://www.ford-trucks.com/user_gal...id=233692&.jpg Find and remove E clip that holds the lever on the tumbler assembly. https://www.ford-trucks.com/user_gal...id=233693&.jpg Now remove the spring clip that holds the tumbler in place. https://www.ford-trucks.com/user_gal...id=233694&.jpg The tumbler assembly will slide out from the back. https://www.ford-trucks.com/user_gal...id=233695&.jpg install new tumbler assembly and then spring clip.(for ease of spring clip install i went ahead and removed handle from the other rod) https://www.ford-trucks.com/user_gal...id=233696&.jpg Reinstall lever on the tumbler assembly. https://www.ford-trucks.com/user_gal...id=233697&.jpg put lever rods back in place. https://www.ford-trucks.com/user_gal...id=233698&.jpg Put door handle back on door and test with a key. https://www.ford-trucks.com/user_gal...id=233699&.jpg Reinstall door panel and your done. Hope this helps anybody that needs to do this Deluxe06 |
Good detail with pictures. Rep given.
Great write up! Were you able to order the tumbler to match your current ignition key?
