Air blows from defrost only
I know there's been posts about this but I've been unable to find them...if anyone has a link in this forum, please let me know...
I checked the HVAC section too to no avail. When I put the control knob on 'Panel', air blows from the panel and the defrost. When on 'floor' it blows from the floor and the defrost, etc... Is this a vacuum issue or a blend door issue, or am I way off? Any ideas/prior threads would be appreciated. '98, 5.4, 4x4, 136,000 miles, anything else? |
It's a vacuum problem, specifically, a distribution selection problem.
https://www.ford-trucks.com/forums/p...ictureid=36391 https://www.ford-trucks.com/forums/p...ictureid=36392 https://www.ford-trucks.com/forums/p...ictureid=36393 |
The dash switch (e.i. a/c, panel,off, defrost, floor, defrost/floor) has the vacuum lines on the back of it.Check there first (cheapest with less hassles). Otherwise I would say the problem is in the heater box with the blend door
What I'm seeing is a single vacuum line coming through the firewall and into the cab. Is this schematic refering to the cluster of vacuum lines and junctions located between the battery and firewall. On my Expedition I do not have vacuum lines that come into the rear of the control panel. Rather, there are three wire clusters.
Thanks for everyone's input... very friendly forum. |
Originally Posted by RED02FX4
(Post 8960639)
The vacuum schematic is for the F150 with a manual climate control head. That single vacuum line through the firewall is represented on the diagram by the line that goes from the junction at the reservoir and the check valve to the function selector switch. That line is not your problem. if it were, you'd get airflow out of ONLY the defroster vent. |
look at the schematic above on the far left. lower corner is the controler and upper area shows the defrost - vent- floor doors. they are controlled by vacuum from the control knob. if you always have defrost, but get flows to additional areas also, then you have a stuck door, or vacuum leak inside the controler block.. i would guess leaks inside the controller between sections.
My screw up... I posted in the wrong area of the forum. My vehicle is a '98 Expedition with dual air. Any help there would be great.
air blows from defrost only
My 2002 Ford Ranger had this exact problem so I started tracing vacuum lines and found the vacuum hose to the reservoir had contacted a hot surface and melted. I cut out the damaged section and spliced with a piece of tubing and the problem went away. I would like to thank all here for adding to the knowledge base as any info seems to be hard to find on these trucks.
Originally Posted by projectSHO89
(Post 8962542)
It cannot be the blend door since the blend door has no effect on where the air comes out.
