Originally Posted by F150xlt
(Post 8946813)
Here's the schematic for an 88. Your 91 used the same turn signal/hazard switch.
Note if you purchase another turn signal/hazard switch there are two types. One is for a tilt wheel and the other is for a non tilt steering wheel. http://i135.photobucket.com/albums/q...0xlt/PG058.jpg Next picture shows the connector pin out of the turn signal/hazard switch and how to test the switch. http://i135.photobucket.com/albums/q...0xlt/PG125.jpg Where are the pictures?? |
turn stop hazard schematics
Many thanks for the diagrams. These may help me find a gremlin in the rear turn signal wiring. 1992 F250 E4OD 460efi . The turn-brake-stop lights all work. Found a bad emergency flasher module, replaced, not the problem. No cruse control or RABS. I have a 6vdc on the rear turn signal wires when ign is in run position. Have removed fuses one at a time in both the under dash and under hood fuse block, voltage is still there. ?? Filament type bulbs work OK, LEDs, some glow dimly when not applied. Was about to install LED tail-brake-stop lights, 3157's Suggestions---?
(Post 8946813)
Note if you purchase another turn signal/hazard switch there are two types. One is for a tilt wheel and the other is for a non tilt steering wheel. Attachment 203747 Next picture shows the connector pin out of the turn signal/hazard switch and how to test the switch. Attachment 203748 |
Six volts is more than likely zero volts. Use a loading test light and not a DVM.
mysterious voltage
Originally Posted by subford
(Post 20941993)
