Replacement topper struts
The gas struts on the hatch of my topper are shot - they won't hold it up any more. Where's the best place to get replacements? Does Crappy Tire have this kind of thing?
Originally Posted by loudfords
(Post 8905506)
Yes but there not cheap $25+ each.... Try your luck at a wreckers or take a piece of 1/2 plastic pipe of the same length as the exposed strut shaft when the hatch is opened, cut a 1/4 slot along it's length and drill a small hole in one end so that you can tether it to the strut. Lift the hatch , snap the plastic pipe in place and viola ! no more bumps on the head. OF course you need two hands to do this so you have to put down whatever your carrying but it's better than clamping a pair of vicegrips on the shaft and will work until you can find replacement struts. Frank |
