Speed limiter shuts off fuel at what speed?
Truck in signature is there a built in limiter in the trucks computer that will limit it to a pre set max MPH?
If there is what is it set at from the factory? Can it be reset to a lower MPH? |
Most are set to 100mph. The limiter can be removed thru tuning. I can set mine as low as 60mph. If some one other than me or I'm out of town that is where I set the truck with a trans only tune.
Yeah you can set the speed limiter to a lower mph.
Your truck should come from factory with the limiter set around 95mph. I have a tuner on my truck and have the speed limiter at 125mph. |
Originally Posted by dkf
(Post 8902846)
dkf and Lubbockguy1979 are spot on
stock 3v v10 is 95 max stock form.. with SCT flash type device you have user options to change it from a min 60 mph to 125 mph. |
