"DOOR AJAR" light wont go off???
My passenger side front door causes my "DOOR AJAR" light to stay on.....(2001 V-10 EX)
Can anyone tell me where to look in the door, and what to look for so I can fix this???.....Its getting annoying having the interior lights on for the first couple minutes everytime I start the truck |
Originally Posted by landcruzr
(Post 8844601)
Can anyone tell me where to look in the door, and what to look for so I can fix this???.....Its getting annoying having the interior lights on for the first couple minutes everytime I start the truck If W-D 40 dont work you have to remove the door panel,remove the door latch and a few of the metal hanger things attached to the latch...Then locate the black thing twisted into the latch with 2 wires connected to it,twist that piece out and then you will find the trigger and you can ussually work it loose with some grease or W-D 40.... |
Originally Posted by tommynos
(Post 8844694)
You can try spraying W-D 40 into the door latch assembly as thats where Ford,for some unknown ignorant reason,put the door trigger...Fords great idea has caused this to be such a common problem and its not a easy fix if the W-D 40 dont work....
I wonder if it is possible to go to a junk yard and get the door switch off another vehicle with the regular button switch and drill a hole in the door of Excursion, install it and rewire it to that switch instead?
I think it would be easier to buy that little switch from Ford. I think they are $6. I am confused about the rear hatch door slamming..............I will start a new thread on it.
Originally Posted by jh818
(Post 8844976)
Can I just grab the wires to the switch and close the circuit on them and not worry about it anymore?
I don't post very often, but I've encountered this problem in 2003 and after replacing all the door ajar switches and the door ajar light was still on, I found that the wiring harness in the rear passenger side door was chafing against a sharp ridge in the door and exposed the bare copper in one of the wires. I wrapped it up with electrical tape and the problem was solved.
I have had the same problem with basically the same solution as Scott, slamming the rear doors, especially the drivers side, it is usually fixed, I also sis the 3/8" tubing in the door seals, and it seems the problem is far less frequent.
When you pull the switch we should spray down the trigger inside the lock assembley so the switch can make the contact inside the lock.
