Ford Truck Enthusiasts Forums
-   Bio-diesel, Propane & Alternative Diesel Engine Fuels (https://www.ford-trucks.com/forums/forum168/)
-   -   3.5 or 5 grams? (https://www.ford-trucks.com/forums/953121-3-5-or-5-grams.html)
kylebryan 04-30-2010 09:17 AM
3.5 or 5 grams?
Ive seen several tutorial videos on using the numbers you get off your titration and i am a litle confused. Some say to add 5g to the number you got off your titration test and some say use 3.5g? Im using NAOH and i need official word. Also i have made 3 one liter batches in the past couple days and they are all coming out very thick with a solid mass in the bottoms of the bottle after seperation. Whats going on?
Rushmore X 04-30-2010 11:16 AM
I don't use NaOH, seems most people on this forum use KOH. hope someone can help you out.
fabmandelux 04-30-2010 11:43 AM
The 3.5 data is from the "Journey to Forever" site, and is waaaaay outdated. If using NAOH you need 5 gms + titration.
kylebryan 04-30-2010 02:45 PM
what are the advantages of using KOH?
fabmandelux 04-30-2010 02:59 PM
Using NAOH produces a solid glycerol that can be a problem, and the glycerol is toxic to plants and animals. KOH produces a liquid glycerol that is easier to handle and dispose of. I use my KOH based glycerol for fertilizer and as a dust suppressant for gravel roads. KOH based glycerol can also be used as an additive in animal feeds.
It does take a little more KOH than NAOH though, but I prefer using it over NAOH. The base amount for KOH is 7 for 100%. I use 90% which requires 7.9 as a base amount.
Rushmore X 05-01-2010 10:42 AM
Always something new to keep up on. I had been using 5.5 g from the old data. Will try maybe 7.7 g? The KOH I use is supposedly around 92%. Sound about right?
fabmandelux 05-01-2010 11:41 AM
By using 7.7 gms instead of 5.5 you should see faster reaction times, and settling times should be shorter also.
Rushmore X 05-01-2010 01:58 PM
Will try it next batch. I leave it to settle overnight. Do use the 80/20 method or all at the same time? thanks again. (Sorry to steal the thread Kyle)
fabmandelux 05-01-2010 03:29 PM
Never needed the 80/20 method. All at once works for me......
