The PERFECT Burnout!
I wanna know how to do a perfect burnout. I have never done one in my life and I'm buying a new set of Toyo Tires and I want to know how to make the old ones melt. http://www.nloc.net/vbforum/images/smilies/help.gif
Some say do a brake stand some say not to. Throw me some Ideas. |
You could power-brake it really easy with a Lightning. Just enough brake pedal pressure to keep the front tires from rolling. The important thing is to do the burnout in the parking lot behind the tire store where you are getting the new tires put on. That way if you burn through a tire and blow it out you won't have far to go to get it replaced. :-X04
how old are you that you have never done a burnout? i dont think i have ever owned (or borrowed) a car/truck without putting it through a little strain on the tires
Just try not to do this!!!!! :-X10
YouTube - Nicks Camaro Tire Explosion |
^OHHHH MANNN That would be the second worst thing ever, worst would be the SRT 10 move. :'(
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/AeYsIFmYT6o&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/AeYsIFmYT6o&hl=en_US&fs=1&color1=0x006699&color2=0 x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********> I'm 22 and only owned the truck since last august, and it's been in storage since October. I have had a Honda Prelude for 2 years and it's a 4 banger FWD so I have never done a proper burn out. |
Yes,
and Iv seen the SRT one before. ): I was trying to find one I saw that a pickup truck tor off the hole fender of the truck. :eek: After seeing it,,,I wont be getting in any burnout contest that's for sure! |
Originally Posted by danorules
(Post 8803436)
There's one out there where the guy lights his brakes on fire because he doesn't have a line lock and he does the burnout too long, superheating the rear brakes.
Wet your tires down, roll forward slowly as you gently apply more and more brake pressure. Just as your truck comes to a stop, with the weight still being transferred forward from the braking, apply enough pedal to brake the rears loose. As they break loose, apply more pedal to bring the rpm's up and burn 'em off. Just remember, burn outs can be rough on the trans because of the heat generated. Don't hold the burn out too long. Stewart |
Stewart's right, you don't want to do this to your tranny.
******** width="640" height="385"><param name="movie" value="http://www.youtube.com/v/eFHwzmzt8GE&color1=0x6699&color2=0x54abd6&hl=en_US &feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/eFHwzmzt8GE&color1=0x6699&color2=0x54abd6&hl=en_US &feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed>*********> |
Originally Posted by bill11012
(Post 8807389)
I will smoke the 6.0,6.4 and new 6.7 after I do the turbo mod and PI heads.
As much as I like the V10 platform, the power curve just didn't appeal to me, that why I ended up with my second 7.3L. But if I had enough cash to do a setup like you're contemplating, huuuuu-doggie would I be grinnin' all the time as I burned through yet another set of tires! :-jammin Stewart |
An FTE member did this one on his V10 Excursion.
******** width="640" height="385"> </PARAM> </PARAM> </PARAM><EMBED height=385 type=application/x-shockwave-flash width=640 src=http://www.youtube.com/v/G7oObDUkY-A&hl=en_US&fs=1& allowfullscreen="true" allowscriptaccess="always"></EMBED>*********></P> The guy that does the best custom tunes for the V10, Mike at 5 Star is working on a kit to sell. He should post the dyno up in the next few months and I can not wait! This is the thread he started about it:https://www.ford-trucks.com/forums/9...-tow-haul.html |
So here's what I did nothing special but I like it :D
******** width="480" height="385"><param name="movie" value="http://www.youtube.com/v/Plj6SfctywQ&hl=en_US&fs=1?color1=0x006699& amp;color2=0x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Plj6SfctywQ&hl=en_US&fs=1?color1=0x006699& amp;color2=0x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>*********> |
Two words... line locks! :-drink
YouTube - Saleen Procharger Mustang Burnout Supercharger P-1SC This was when I did a nose to nose burnout with my buddy's 2002 GT vert. LOVE new tire day! YouTube - Saleen Burnout with 2002 GT convertible |
As far as doing the perfect burnout, if you have an automatic tranny which most likely you do, put it in low gear and push the brake in just enough to keep it from rolling.
If you have a manual, use the left foot to push in the clutch and the right foot to push the brake and the throttle at once. Spike the throttle up to around 3-4K to break the tires lose, then drop the RPMs down to around 2K and let 'em roast all day long! |
Originally Posted by TennesseeMustangPerf
(Post 9115291)
If you have a manual, use the left foot to push in the clutch and the right foot to push the brake and the throttle at once. Spike the throttle up to around 3-4K to break the tires lose, then drop the RPMs down to around 2K and let 'em roast all day long! I see you have some experience :D:D:D |
