Clicking noise..
'05 Expy while in reverse I here this occasional click sound coming from underneath the driver side dash. Only does it in reverse.
Any ideas? B. |
bump......
the only clicking I had was because of a bad rear axle; but your symptoms do not match mine.
I would check the 4X equipment, you may have a vacuum leak or something associated that may be causing it, but I truly could not say for sure. Good luck Steve |
I have the same sound in my 03 Expedition. I have no idea what it is but it sounds like it is coming from the under side of the column. I thought it was the key and remote but it is definatley in the column when in reverse.
