Mobil 1 Synthetic ATF
Just used this stuff to change my transfer case fluid. Took 2-1/4 quarts BTW.
Mobil 1 Synthetic Automatic Transmission Fluid (ATF) Reading the bottle, and the above web page, Mobil says it replaces Mercon, Mercon V, and Mercon LV! It also notes that it is NOT a recommended replacement for Mercon SP. As we know, Ford says LV now replaces SP. We also know that Mercon V will destroy the servos in the Torqshift. So how can it be that Mobil 1 Synthetic ATF can be a replacement for Mercon V, and Mercon LV, but not be suitable for SP applications? Just tossing this out for discussion. Your thoughts? |
Originally Posted by bpounds
(Post 8753435)
Mobil 1 Synthetic Automatic Transmission Fluid (ATF) Reading the bottle, and the above web page, Mobil says it replaces Mercon, Mercon V, and Mercon LV! It also notes that it is NOT a recommended replacement for Mercon SP. As we know, Ford says LV now replaces SP. We also know that Mercon V will destroy the servos in the Torqshift. So how can it be that Mobil 1 Synthetic ATF can be a replacement for Mercon V, and Mercon LV, but not be suitable for SP applications? Just tossing this out for discussion. Your thoughts? you would not have a clue. They smell and look the same, except one bottle is gray and the other is red. Interesting... |
Same thought here. I would use it in the p.s. pump but would be scared to use it in the tranny. What is the advantage vrs. the risk? I don't personally see one.
my truck is not under warrenty and I have the 6spd manual, I was going to change my tranny fluid this week and replace with the mobil 1 syn atf I think it would be good right?
Just my opinion, but I think it would be perfect for a manual.
We know Ford does not make Mercon....
