2007 Ford Grille Badge, replacing--help please
My new insert has blue stuff over what I think is adhesive on the back.
Is the factory one stuck on with the clips and two sided foam tape? If so how do you get it apart? Thanks guys---Bob |
BERRY!!! TYLUS!!!.... where are you guys!! Gimme a bit to find them. They're probably outside under their Expys trying to find new ways of giving them the 6-Million-Dollar-Man treatment. You know... Better, Stronger,Faster!!.... :-X22
Huh? It was delivered today. Just need advise.
http://www.alldatadiy.com/alldata/AF...4165/143285817
Hard to tell if it's just double sided tape or there are clips. Look at the back of the grille, crawl underneath the truck with a light. If you see two tabs at the back of the grille where the emblem is, there is your answer. |
http://superdutydiesel.com/wiki/show_image.php?id=446
http://superdutydiesel.com/wiki/show_image.php?id=462 8C3Z1542528A Looks like double sided tape with 3 small tabs for alignment. Heat gun and some work should get it off. |
I'll do that. I don't have a heat gun though.
I was thinking about adhesive remover or fishing line. Saw it off with line. I have the exact one in the picture. Hair dryer ?? And thanks for getting back. Most appreciated. Very much so. Bob |
Holy crap Batman, rivets? I thought it was clips or something easily removed.
ExpyBob, PM me with your email I will send you more details on this.
Hi Berry1234
I went ahead and sent it to you. Thanks. |
Originally Posted by berry1234
(Post 8741110)
Hard to tell if it's just double sided tape or there are clips. Look at the back of the grille, crawl underneath the truck with a light. If you see two tabs at the back of the grille where the emblem is, there is your answer. They are a pain in the butt and I ended snapping one of the tabs. I need a replacement badge cause I have severe cracking and bubbling on the plastic overcoat...but local "stealership" wanted $50 for one. |
Thanks. Every time I open the thread the pictures are different.
I'm going to try it Saturday. |
Originally Posted by ExpyBob
(Post 8744861)
Just replaced mine. The original one did not have the adhesive tape. Pull the big upper shroud/cover and you can get your hand down in the area behind the emblem (barely). 2 8 mm nuts, remove them. I used a 1/4" ratchet and deep socket. You may need to pry the old emblem out - I used 2 putty knives but first put masking tape around the area to keep from messing the paint up. Install is the reverse.
B/R, Randy |
Where did you buy?
Where did you buy your part? If you dont' mind, how much?? Thanks.
I am seeing part number 8C3Z1542528A for about $15 online from Ford Parts Guy.
www.partsguyed.com But when I search the grille parts for the 08-07 is shows up as $34. Strange. |
