Transmission Removal - 2004 F-150 5.4L 4WD
I am replacing the flexplate in a 2004 F-150 Supercab 5.4L 4WD. Does any one know the secret for getting to and removing the two transmission-to-engine bolts on the top of the transmission?? :-banghead
JRR 2004 F-150 SuperCrew 5.4L 4WD 2008 F-150 SuperCrew 5.4L 4WD |
Long extension over the top of the trans? Is there any access with a wrench from the top?
Lower the transmission and use a long extension with a swivel socket.
By "lower the transmission" - do you mean remove the crossmember and lower the rear end of the transmission a little to make more room on top?
Yes.
The cross member should have been removed by now. It has to come out to replace the flex plate. |
The crossmember is removed but I was afraid to lower the trasmission. I didn't know how far I could go and didn't want to risk damage to the motor mounts without asking the best way to get those bolts out. Besides - this trick is not in the Ford manual . . .
So would this be the correct procedure (starting with all transmission-to-engine bolts installed: 1. Lower the rear end of the transmission and remove the upper bolts. How much can I lower it? 2. Raise the transmission and remove the remainder of the bolts. 3. Remove transmission and replace flex plate. 4. Install transmission - lower bolts. 5. Lower the rear end of the transmission and install/torque the upper bolts. 6. Torque the remaining lower bolts Thanks - JRR 2004 F-150 SuperCrew 5.4L 4WD 2008 F-150 SuperCrew 5.4L 4WD |
