1985 f250 6.9 rocker arms
what are the best rocker arms to use in my motor. i am doing a little tuneup since i have to replace my oil pressure sending unit.
7.3 style rockers are much stronger, direct bolt on swap.
Dave, what is the difference between the two styles? I have yet to have the chance to open up a 7.3 and was wondering.
83 thru 86 6.9 rockers
Picture from DPS Performance. http://www.dps-performance.com/image...s/DSCF0027.JPG Pivot point after 300 miles, notice the wear. http://www.dps-performance.com/image...s/DSCF0031.JPG From the bottom, round means the rockers can shift around in a circle. http://www.dps-performance.com/image...s/DSCF0036.JPG 87 6.9 and 88 thru 94 7.3 style rockers http://www.dps-performance.com/image...s/DSCF0033.JPG Square means no circles. http://www.dps-performance.com/image...s/DSCF0037.JPG Rockers that go in circles make push rods that look like this, pictures from my collection now. https://www.ford-trucks.com/user_gal...id=115512&.jpg And that makes pistons sit like this. https://www.ford-trucks.com/user_gal...id=190136&.jpg With the block being destroyed in the process since it cracked when the valve made contact with the piston and broke the piston. |
O.K. I see now. I am still looking for a set of 7.3 rockers myself. I have a buddy in Petersburg ky with a 93 F250 4x4 that runs it real hard and does little to no maintance on it. It also has the zf5 in it. I told him that when he blows it up i want first dibs on the truck lol. It also has a chuffing valve in it for the last 3 years and is still chugging along. i wonder if I will ever get a chance at that thing lol.
You may be waiting for a while yet.
I priced them for someone a while back, and if I remember right they were not that expensive. Let me think a while, I may be able to remember where I priced them at. Probably have a link on my dead hard drive. |
someone mentioned getting a set for 96 bucks not to long ago. I forget which store it was, but I thought it was cheap.
Originally Posted by kenpobuck
(Post 8724115)
would you suggest me changing the pushrods also?
If the push rods are straight and within spec for length, there is no reason, they are the same push rod.
mabc926, That would be great. Shoot me a pm about it.
Who sells the 7.3 style rocker arms? Checked Napa and they have the same part listed for 6.9 and 7.3, which is the 6.9 style.
