09 Flex-part fell out
http://http://s964.photobucket.com/a...t=flexpart.jpgWhat is it??
A small plasticpiece fell out of the bottomof the engine compartment when I slammed the door. Looks like some sort of relay holder the following numbers are stamped on it; AE93-8A194-AA PA-GF33 BFPUK CAV 6 Any ideas? I'm 400 miles from home at the moment. Thanks psajunk |
Originally Posted by psajunk
(Post 8695408)
What is it??
A small plasticpiece fell out of the bottomof the engine compartment when I slammed the door. Looks like some sort of relay holder the following numbers are stamped on it; AE93-8A194-AA PA-GF33 BFPUK CAV 6 Any ideas? I'm 400 miles from home at the moment. Thanks psajunk I'd say the best you could do is check all your fuseboxes and relay boxes (got your owner's manual? If not go to fleetford.com) to make sure everything is still there and if it is, assume that someone at the factory left you an extra part... Weird, George |
http://i964.photobucket.com/albums/a...l/flexpart.jpg
Fixed your pic for ya |
That is the clamp that holds the top of the radiator in, there are two, one each side on the top. The two little tabs stick through the "G.O.R." or radiator frame. You might be fine without it, or, your radiator may jump around enough to cause an issue. I've been living with only one for years.
