radio removal
Ok I have the right tool for the job.stuck them in the head unit and the radio doesn't move.......:-banghead. Any ideas what I'm doing wrong?
What I did was push them all the way in then apply pressure outward while wiggling the radio from side to side a bit. I thought that mine was stuck when I removed it as well.
first beat your head on it then get another et of hands and in 2 hours you should have it. when we did my dads truck it would not move then it just came out, they have to be in there just so so.
Make sure the hooked end on the tool is pointed inward toward the radio :D
I just popped the dash panel out, just takes a few minutes then reach back around and pop the deck out.
Originally Posted by Layson
(Post 8591843)
Originally Posted by superduty4x4
(Post 8591859)
That's what I did the first time too :D
Originally Posted by megawatt00
(Post 8591624)
Originally Posted by snakedoc
(Post 8591632)
https://www.ford-trucks.com/forums/a...8&d=1257890573 How the tool tips push the spring clips inward when you push the tools outward. https://www.ford-trucks.com/forums/a...7&d=1257890573 |
Great pic's Robin. I need to do the same on my removal tools.
Nice pics Robin...
I took a small pry bar stuck it in the tape hole. After that face plate brakes off it is much easier to see whats going wrong... |
Nice Pics Indeed.. I was just thinking when i opened this thread that i need to take pictures of taking out the radio. And Bam.. You got it handled.. Nice.. Nice tool.. I made up something similar.
Originally Posted by maevans
(Post 8591965)
Too many posts about fighting with getting it out. Knowing just how it's held in helps. If the tool is off by even an 1/8", in or out, that sucker don't want to come out. Been there, done that. |
Originally Posted by 4inchlovin
(Post 8591992)
Originally Posted by danskool
(Post 8592021)
(Post 8592041)
That doesn't suprise me at all I can see you laughing as you did it too.
You know me too well brother!!!:-missingt |
(Post 8592021)
I was actually given the tools by an audio installer. I just added the tape. Edit : Thanks to you as well Megajim. |
