Gear Selector Replacement?
I bought my truck with the OD tip broke off of my gear selector. The stealership wants like 250 to replace the gear selector but i talked to the parts guy and i could get the gear selector arm, the OD button and cap for like 90 bucks. Has anyone replaced their gear selector and is it much to difficult. They said its about an hour and a half worth of labor.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
Does anybody have any info on the gear selector? the end of mine has 3 wires showing which must be part of the OD button. Obviously this part is serviceable if Ford can do it in an hour and a half. Im just lookin to save on labor costs and DIY Does anyone have any info or diagrams on how the gear selector arm connects to the steering column. I want to have an idea of what im getting into.
remove dash bezel, remove steering column cover use a punch and hammer drive pin out of shift lever un plug wire harness. reverse procedure to install.
yep real easy! Might not even have to take the instrument cluster bezel off if your careful
Awesome guys Thank you. Ill be doing this as soon as I get the parts in.
Originally Posted by tjbeggs
(Post 8568156)
Originally Posted by helifixer
(Post 8568893)
I always pill it just to get a good cleaning, I also normally remove the clear cover and dust the instrument panel. the customers love it!
Alright sweet, I just ordered the part from partsguyed.com so should be here in a couple days.
