is this the right 6.0 tranny cooler upgrade?
found this on discount ford accessories but it doesn't list a part number, but it does say for 6.0 is it right? it says it fits 03 to 07 6.0 so it will bolt right up to my 04 like in all the other posts?<TABLE style="BORDER-BOTTOM: #24569d 1px solid; BORDER-LEFT: #24569d 1px solid; BORDER-TOP: #24569d 1px solid; BORDER-RIGHT: #24569d 1px solid" border=0 cellSpacing=0 cellPadding=3 width="100%"><FORM onsubmit="return _CF_checkupdateQuantity(this)" method=post name=updateQuantity action=index.cfm?action=updateQuantity&orderitemco unt=1&siteid=213879><TBODY><TR><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText align=left>OEM Catalog
Cooling, Trans oil cooler, Trans cooler, COOL & HOS ASY TRANS - 6.0 liter turbo diesel </TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right></TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right>$425.32</TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right> $301.12</TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right> </TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right>$0.00</TD><TD style="BORDER-BOTTOM: #24569d 3px double" class=tableText vAlign=top align=right>$301.12</TD></TR></TBODY></FORM></TABLE> |
ok did a little more searching, 31-row part-number is 5C3Z7A095B correct? price $398
5C3Z7A095CA part-# is for a 26-row cooler price $301.12 correct? discount ford doesnt even list the 31 row part number i had to search by part number and find it. |
Originally Posted by SuperDutyScaler
(Post 8558275)
5C3Z7A095CA part-# is for a 26-row cooler price $301.12 correct? discount ford doesnt even list the 31 row part number i had to search by part number and find it. If you don't want to wait and find a deal on a used one (CL, junkyard, eBay), you will probably get the best deal from Ed unless you've got a local hookup: www.partsguyed.com www.partsguyed.com |
so part number 5C3Z-7A095-CB is the new 31 row 6.0 cooler? as long as it has the same mount locations ill get that one. yea ive been lookinh for a couple of months now and i cant find any, ebay gets on my last nerve every bid at the last second somebody outbids me so i had enough with it all.
brian42 i went to ed site and he doesnt list the new part number at all, should i just try and contact him instead?
The "new" cooler is 26 row. They do not make the 31 row anymore...
Originally Posted by dlibson
(Post 8559965)
yes they do. 5C3Z7A095B www.partsguyed.com |
They do not replace them anymore if you go to the dealer. It is not a new one...
(Post 8560103)
I just looked and Ford has stock at the depot(s) they are avail if you want to buy one. someone is giving you bogus info. |
ok so what is the part number for the new updated 26 row cooler. i read its just as good and cheaper so ill buy that one if i can get the right part number
thanks to megawatt00 in the 7.3 section here is the new updated higher effecieny 26 row cooler's part number 5C3Z7A095CA. and its only $301.00 from ed www.partsguyed.com. got mine ordered should be here next week
(Post 8562719)
didn't get the order yet? I'll keep a eye out for it. |
To recap:
The 31-row cooler is the older 6.0L tranny cooler and the 26-row cooler is the newer 6.0L tranny cooler. Here are the current part numbers for both: 26-row 5C3Z-7A095-CA 31-row 5C3Z-7A095-CB The 26-row is a redesigned unit that has about the same cooling capacity as the 31-row (and is about $100 cheaper). I don't remember the exact post it was on, but it was posted by Mark Kovalsky. He was a Ford transmission engineer so I tend to believe what he says. If you can't (or don't want to) find a used one or have a local hookup, Ed's got 'em both: 26-row: www.partsguyed.com 31-row: www.partsguyed.com And, yes, they both have the same mounting and connection points. As for dropping them into something besides a 6.0L, you may have to modify your lines to/from (I know you do on a 7.3L). |
Originally Posted by brian42
(Post 8563394)
To recap:
The 31-row cooler is the older 6.0L tranny cooler and the 26-row cooler is the newer 6.0L tranny cooler. Here are the current part numbers for both: 26-row 5C3Z-7A095-CA 31-row 5C3Z-7A095-CB The 26-row is a redesigned unit that has about the same cooling capacity as the 31-row (and is about $100 cheaper). I don't remember the exact post it was on, but it was posted by Mark Kovalsky. He was a Ford transmission engineer so tend to believe what he says. 5C3Z7A095CB is replaced to the 5C3Z7A095CA the only 31 row avail is the the early 7/19/04 to 11/04/04 5C3Z7A095B so now I understand why dibson was saying the 31 row was not avail. :-X18 |
Originally Posted by y2kfordparts
(Post 8563498)
