Originally Posted by MADVAN
(Post 8554536)
It was also something that needed to be done.
Originally Posted by Talyn
(Post 8554554)
The Sheep shagging?
WOO HOO T Bill |
(Post 8554536)
BTW--Excellent, on the ranch dressing.
It was also something that needed to be done. Bill |
Originally Posted by tjbeggs
(Post 8554571)
I had hoped that didn't go unnoticed!:-fire
(Post 8554611)
Sheep and Ranch Dressing? :P
HAAHAHAHAHA.
he said EWE! |
(Post 8554611)
fubar member: hotrd3g / Nick Smith (2053316) |
Bad bill,
*throws bill a red bean* |
Yea. Your right.
I feel bad for the truck though. Its in pleasantville! What is worse, is i would still help if he could get the foot/head out of. Chalk it up as truck stress. Bill |
(Post 8552561)
In oem form the 97-E4 is a stronger unit than the 99-4R.
This is what i see from a keyboard. Trans goes 20 miles has a failure. It was able to limp home under man1. After the man1 run it has no F and R. "The limp home added to the failure" Selection of man1 runs at max epc. This was enough to engage but slip. The unit needs to come out. Its melba T This all stemmed from 32K on the back of the truck. That was knocking the door of 40K total! If changing the pcm for the 4th time makes you happy so be it. Its your time and money. I see bad builds and troubleshooting. .02 Bill Also Bill, how do you see bad builds? You weren't in my shop checking clearances as it went together. When you build a tranny do you use a Farrow to check your bore centers. I do. I build high speed spindles that weigh 1800 lbs and spin 20000 rpm to grind and surface steel. Ever heard of a VTL? Probably not. Its a vertical turning lathe. Only heavy industry Uses them. What I'm getting at is around .000001 clearance. For me to do what I do for a living don't you think I would apply my knowledge of a reciprocating assembly to the build. Everything was fine for two days then I had electrical problems and lost forward gearing. That is what I needed answers to, not a place to build me one, or to learn what the laws are for hauling, or for what trucks and trailors brakes are rated at. Now I am enjoying this, wasting my time on here. And you just read it all so where did it just get you? Lol. What a bunch of losers you are. Making assumptions and causing drama. And say its me. Again all I did was ask questions. You guys are the ones who couldn't answer them but instead talk sheeyaht. |
Originally Posted by hotrd3g
(Post 8556884)
I agree its fried but you forget something, all my troubleshooting info has came from you guys. I asked you guys simple questions and it seems Bill is the only one that knows what he's talking about. All the rest of you are the keyboard pirates.
Easy there tiger , there is a great deal of knowledge here , & they were all trying to help you I hope your tranny case warps from something you didn't do. Also Bill, how do you see bad builds? You weren't in my shop checking clearances as it went together. clearances & tolerances aren't all that is needed . You have to know what is acceptable & what is not , that only comes from experience When you build a tranny do you use a Farrow to check your bore centers. I do. I build high speed spindles that weigh 1800 lbs and spin 20000 rpm to grind and surface steel. Ever heard of a VTL? Probably not. Its a vertical turning lathe. Only heavy industry Uses them. What I'm getting at is around .000001 clearance. For me to do what I do for a living don't you think I would apply my knowledge of a reciprocating assembly to the build. This only states your overconfidence in your own ability. Everything was fine for two days then I had electrical problems and lost forward gearing. That is what I needed answers to, not a place to build me one, or to learn what the laws are for hauling, or for what trucks and trailors brakes are rated at. Now I am enjoying this, wasting my time on here. Yeah , we are too And you just read it all so where did it just get you? Lol. What a bunch of losers you are. Careful , most of us losers belong to all the powerstroke sites Making assumptions and causing drama. And say its me. Again all I did was ask questions. You guys are the ones who couldn't answer them but instead talk sheeyaht. Again, careful [QUOTE ] so you were nosy. -------------------------------------------------------------------------------- Quote: Originally Posted by RRranch Did the builder completely clean the system out each time. The factory cooler is nearly impossible to clean. I usually replace them. Also that model usually has two tranny coolers on it. It could just be full of trash and burning up. Did he put an inline filter on the return line from the coolers? I hope so. I've never rebuilt one where I didn't do that. It was a 5 dollar insurance policy as far as I was concerned. Time for a new builder if you ask me. And have him start from scratch. I fired a guy at my shop that did this almost exactly the same. When I was going through his toolbox before he went out the door, he had hundreds of new transmission parts from kits he had used in the drawers. That's ne reason we had so many comebacks. Never had another one after he left. Was he a builder before he worked for you? Maybe he has been collecting parts over the years. I don't see anything wrong with that. I have a 10000 dollar snap on box with probably 200000 dollars worth of tools. If I caught someone in my box they'd be picking up their teeth with broken fingers. That's also breaking and entering whether in your shop or not. Yes I said 200000 worth of tools. Hell I have a precision level that cost 80000. No I won't explain what I do for a living, I just wanted to finish blowing that last post out of proporsion. It didn't help. Just hit a nerve. I can't stand nosy people. [/QUOTE] You should try to relax , you can still get help if you get off the high horse ... |
(Post 8556884)
I have asked simple questions. (no reply)(first tread) They are used as a guide for me/you to source the failure.
(Post 8556884)
No i did not have to be at/in the your shop to see or check anything. Below is enough to make my statement. "I found the forward 6pinion planetary didn't have the inner needle bearing that sits against the sunshell gear, all the regulator valves in th accum. valvebody were stuck, and it had a ninth checkball in the case about an inch to the left of the manual valve far rear."
(Post 8556884)
Uses them. What I'm getting at is around .000001 clearance. For me to do what I do for a living don't you think I would apply my knowledge of a reciprocating assembly to the build. It gets you no where
(Post 8556884)
(Post 8556884)
are for hauling, or for what trucks and trailors brakes are rated at. Now I am enjoying this, wasting my time on here. And you just read it all so where did it just get you? Lol. What a bunch of losers you are. Making assumptions and causing drama. And say its me. Again all I did was ask questions. You guys are the ones who couldn't answer them but instead talk sheeyaht. Seems you like to dish it out but cannot recieve. With trucks this old you cannot assume the trans has all stock parts or correct year core. (6 pinion foward non stock item). You have to start with case ID and VB ID first so you will have the correct combo of parts. This is important for ball size and location as well as gaskets used. Do you have this info? Using the method of install this due to this is what was removed is not going to work. The first builder could of screwed all that up. You have to start from square 1 to move foward. Go assult/insult the first builder. Dont bring it here and expect anything. As you can see its more than remove and replace parts to build a E4 Question The trans passed an air test of the center support before the VB's were installed? Bill |
Rick/TJ
OP stated this in the other tread and here. "and it had a ninth checkball in the case about an inch to the left of the manual valve far rear." I see this as a problem on what the OP decided to do. Sounds like he jumped on the first builder as if it was a mistake and he was an arse. (9th ball) It may or may not be case depending on the build parts used. Bill |
I'm amused he decided to insult 3 of the most knowledgeable people on FTE.
Thats pretty Brave. 200k in snap on gear, thats a tool box and a few wrenches, not impressed. hahahahaha. While I love my snap on tools. I'd rather go by the 10 dollar wrench with lifetime warranty than the 80 dollar snap on equivalent. Couple that formula with a few sockets, some wrenches and screw drivers and a tool box, a 3k set of tools will cost you around 30k+ with snap on. I know for a fact they are not cheep. I looked at their tool boxes for myself when I went to get one, i wasn't dropping 15k on a tool box, and that was with my discount at snap on. (Which you don't get, neener neener) |
