1961-1964 262 6 cylinder questions
I just bought a '60 ford f100 with a '61-64 commercial 262 swapped into it. It's supposedly in the same family as the 215 and 223 motors.
I think it needs a valve adjustment, Does anyone have valve lash specs for this motor?? Or any other sources of info?? I'm havin a hard time finding info on it, thanks for any help. Knoxville |
.019 should be about right.
Thanks.
Know of any good sources of info for these motors? I have a feeling i'm gonna need it later on. |
Timing is at about 6-10 degrees.
Lash .019. Plug gap .035. Point gap .025 I got these by just googling ford 223 tuneup. A factory service manual from 1958-64 truck would give you a solid ballpark figure. |
No forum here for that?
262
You're in it. You can also try the appropriate years pickup forums here. If you can't find help/directions to/ or what ever here it does'nt exist. Great site/ people. Only my opinion.OBCB
Yes, there is:
61 - 66 F-100 & Larger F-Series Trucks Knoxville - mights well go to the source, did U C the above, one of our forums? Go to the very top of this page and click on Forums (is in grey colored area). |
i have 64 with 223, want to cam it up, bore 30t. over ,put 4brl manfoild on with a split . what do you think. will
223
Originally Posted by wills 64
(Post 8943415)
:-X25 |
