2003 f-350 7.3 drivers side 4x4 noise????
i have a lot of 4x4 noise coming from drivers side, almost sounds like bad bearing. i also have to replace a wheel bearing hub assemly on the same side do to noise in 2 wheel drive. so i guess my guestion is what could cuase this growling in 4x4. first i was thinking hub because it is extremely hard to turn that side, while the other side is very free? but now im second guessing myself because i can lock the hubs and leave it in 2 wheel drive and it doesn't make any noise, only when 4x4 is enganged, and it is under a load, or decellerating! any suggestions?
I would have to think by your screen name you are a Broken Lizard fan!!! me too!
I think you might have another bad wheel bearing assembly. I had the same issue and my whole passenger side was FUBAR, replaced everything back in NOV and my 4x4 hubs and bearings are good to go! where in Mi? |
Mine did the same thing on the drivers side. just rebuild it and it will be easier to turn and the sqeak will go away.
