Karma finally gets me... ESOF problems
:-lamesign :-lamesign :-lamesign
Well at least I got almost 2 years out of this silly system. My 4x4 has gone intermittent. It works sometimes and not others, but as of the past few days it fails more often than not. I think I know where the problem is but I haven't had time to tear into it yet. I guess I better go get a mityvac and prepare to bend over on a repair bill. I think I might have some ball joints going bad, need shocks, turbos been making weird sounds... |
Originally Posted by superduty4x4
(Post 8485353)
Chase you can do those Balljoints on your own pretty easy. It is not too bad of a job. If you sweet talk Mark (Milleroutdoors) a little he might even let you borrow his shop down here and we could swap those out in no time. LOL...
Originally Posted by Layson
(Post 8485487)
I've done one side so I know what I'm up against already. I could rig a way to drive the big knuckle seal on, and beat the ball joints in/out if I try hard enough I know. Ken... STFU :D |
than what are you complaining about... LOL
(Post 8485547)
you can just get out of your rig and turn the dial... LOL
Chase, Ive got a seal driver that I made that you can use. Or if you need a hand let me know. I've done quite a few ball joint jobs so getting pretty good at it
Walt, did u change out that CPS????
Originally Posted by PwerStroke99
(Post 8485704)
LOL< its a 10 minute job! just messin man. Hopefully that Black CPS clears that code.
(Post 8485642)
Walt I may take you up on that. I still need to install those sway bar end links I got from you along with a few other things :D |
