Volant Cold Air Intake Kit
Anybody ever hear of this FIPK? It supposedly is the only inkake kit to have a box covering the filter. I currently have an Airade FIPK but it has the loud whistling from the Poweraide throttle body spacer i put on. I was told if I put the Volant Kit on with the box i wont be able to hear the loud whistle. Any Suggestions?
2000 5.4 EXP Magna Flow Poweraide Airade |
Volant does cover the filter to make it a TRUE COLD AIR INTAKE as opposed to others that utilize warm engine compartment air. There are a few posts about the throttle body spacers whistling. I do not know if the Volant Intake will lessen the whistle.
So does the box have an intake routed through the fenderwell or somewhere else? Or, is it a box over the filter taking in warm engine bay air . . . ?
:-X25 |
It utilizes the same connection to the outside as the stock intake. The filter is covered so it only uses cooler outside air.
