oasis reports
hello all, if you need an oasis report done, post of your vin or pm your vin and ill run an oasis for you. give me some time to get back with you as im working during the day and cant always check the board. thanks chris
I'd love an oasis report for the truck I just bought. Here's the VIN: 1FTNX21F3YEC35635
I've seen something about the Oasis just showing the last year, but there is also a way to get full warranty history, is that possible? You can email me at hpcbmw@yahoo.com. Thanks for the help! |
Good man.
I'll have to get you mine asap for this also. oh wait, i think i have it on here. *looks* 2FTHF26F2RCA49067 I'd also like to report that windows seven found no files named 2FTHF26F2RCA49067. Hahah! |
hpc recheck your vin and repost. vin is nott valid
tayln oasis only goes back 10 years the only info thatt come up for that vin is the fact therre is a rrecall 09s09 cruise control deactivation still open on it. ttake it to the dealer tot have it performed free of charge.
Looks like I had the last number wrong: 1ftnx21f3yec35636
Thanks! |
hpc
you have a recall 09s09 cruise modifcation still open on your f-250. Cust Comments: CUST SAYS THE KEY STICKS IN THE START MODE AND DOES NOT RETURN INTERMITTENTLY CAUSING THE STARTER TO GRIND Tech Comments: 1 VERIFIED CONCERN. R AND R IGNITION LOCK CYLINDER AND LUBRICATE. START SEVERAL TIMES. COULD NOT GET TO STICK Cust Comments: CUST SAYS THE TRUCK ROLLS EXCESSIVLYIN PARK ON THE PARK PAUL ABOUT 6 8 INCHES Tech Comments: FLUID OK. ROAD EST SHOWS TRANS SHIFTS PROPERLY AT THIS TIME. PARK PAUL WORKS OK. NOTE, MUST APPLY E BRAKE BEFORE PUTTING Cust Comments: CUST STATES POWER POINT INOP Tech Comments: VERIFY CONCERN. FOUND GPS TO BE DRAWING TO MUCH AMPERAGE. FOUND BLOWN FUSE REPLACED FUSE RETESTED AND VERIFIED REPAIR Cust Comments: CUST STATES THE TRUCK STALLS WHILE DRIVING HAD THE TRUCK TOWED IN DIAG AND REPORT Tech Comments: TEST SYSTEM STALLING CONCERN PERFORM DIESEL DIAG FUEL SYSTEM AND INTAKE SYSTEM GOOD ROAD TEST WITH WDS MONITOR AND RECORD PIDS FOUND LOSS OF RPM SIGNAL W/STALL REPLACE CAM SHAFT SENSOR AND RETEST ALL OK Cust Comments: SUBMIT FOR REFUND TO 07S57 ******* MOTORS INVOICE #*****11.18.2002 $100.00 DEDUCT |
Great offer!!! Reps to you!!!!
Thanks Chris, great info!
1fmnu41sx1eb19157 That is for a ford excursion i plan on looking at this week.....if you could help me out i would be awesome.
brown
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>VEHICLE TOWED IN NO START CRANKS THEFT LIGHT FLASHES</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>NO GROUND IN HARNESS EEC (QUICK TEST) DIAGNOSIS</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>RECALL 01S21 DUE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED SAFETY RECALL</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>MLDG ON PASS SIDE DOOR LOOSE.</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD MLDG & REINSTALL</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>BRAKES SQUEAL WHEN IN 4X4</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>INSPECT & CLEAN FRT BRAKES</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>HEADLIGHTS OUT OF ADJUSTMENT</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND HEADLIGHT RETIANING CLIP MISSING. REPLCED CLIP</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>LOCK ON LEFT FRT IS INOP</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & REMOVED CYL & REPLACED CYL ASSY, RECODE LOCK</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>PANEL ON REAR DOOR ON RT IS LOOSE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND MLDG CLIP BROKEN, REPLACED MLDG</TD></TR></TBODY></TABLE> <TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>CUSTOMER STATES THAT VEHICLE HAS RECALL RECALL 05S28</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED RECALL 05S28 AS INSTRUCTED</TD></TR></TBODY></TABLE> |
Thank you so much, I really appreciate you taking time out of your day to do that !
no problem
Chris, When is the best time to call you about some service work ?
Don't what to bug you at work. Mark |
im at work til 5pm, but you can call whenever, i leaving work right now, if you want give me a call and we can go over the work you need. 517-920-3048. thanks
