P0171, P0174, P0430 on 1998 Explorer
I have these codes up for system too lean, bank 1 and 2, and 430: catalytic system below standard. My Explorer is rough idleing in the morning, or even stalling out. Once I accelerate or after a few moments, the rough idle is gone and the car rides great.
I suspect water is condensing/mixing in the gas line. I used Carb Cleaner to check all over the top of the engine for vacuum leaks and found NONE! I've treated the fuel tank with sea foam to try and fix the water problem in the gas, but it isn't a solution. Any ideas? |
Sounds like intake manifold gaskets.
Thanks Scucci. I am going to clean the MAF sensor/inspect it and look there. I appreciate it. If you think of anything else- I'm all ears.
Intake manifold gaskets are one common issue for a lean condition contributing to a rough idle. I'd also suggest you consider the Differential Pressure Feedback EGR (DPFE) sensor as another common issue on the Explorer that could cause symptoms and codes such as you describe. Whatever the issue, you want to remedy it as soon as possible to hopefully avoid more costly damage to your catalytic converters.
-Rod |
so should the intake be removed and gasket installed?, it could not be a sensor? thanks
It could be either the intake manifold gasket, the intake air tubing between the MAF and the throttle body, or the DPFE. I'd start by checking for a vacuum leak and if you don't find one, start with the DPFE.
-Rod |
I also have the same P0171 code. Was driving to a friends house an hour and a half away this past weekend and the truck drove perfectly fine until I got there. Weirdest thing for it to happen so sudden. Since then it's been idling rough, hesitates when I accelerate, some pinging and generally running poor. I replaced the fuel filter and air filter and it ran a bit better but still far from perfect. I have a 98 Explorer with 4.0L v6. Any ideas?
Pinging and rough idle, i'm willing to bet you got a bug on your MAF sensor. remove it and clean it off.
If you think you have some power loss I would look into the plugs, poss replacement.
Originally Posted by Wilber15
(Post 8355884)
-Rod |
Are the intake manifold gaskets difficult to replace or if I choose to have someone else do it is it expensive? I'm a novice at this.
Could it be clogged fuel injectors?
Turns out the plug in the number 6 cylinder was bad. It was burned out so bad the firing points on the top of the plug were burned off. Hope it didn't get in the cylinder and damage the engine. I also had fuel injection treatment done. Runs like a champ! Thanks to everyone who posted a reply. You all did truly help me.
