Looking For a Body Lift for 04 F250
Hey guys, Ive been looking around for a 2in Body Lift for a 2004 F250 Super Crew. I have a 6in lift with 37s on now, and im rubbing a little on the backside of the front tire well when the wheels turned all the way. Besides cutting out the fender and having medal work done or going to a smaller tire (which isnt gonna happen); I cant think of another option besides body lift. I havent seen any body lifts out there for 2004s. Any help would be great.
There aren't any body lift kits for Super Duty trucks. If you want to lift the body (which looks like doo-doo IMO) you're on your own to figure it out.
Too bad that you have the diesel engine... BDS makes a 3" body lift kit for the 1999-2003 Super Duties with the gas engine.
Ford BDS Body Lifts, Body Lifts Ford Trucks, F-150 Body Lift, F-250 LD Body Lift, Super Duty Body Lift, Ranger Body Lift <CENTER>3" Body Lift - 1999-03 - F-250/F-350 Super Duty, 2/4WD http://ep.yimg.com/ca/Img/trans_1x1.gif </CENTER>Fits - 1999-2003 Ford F-250/F-350 Super Duty, 2WD and 4WD 3" Body Lift Kit Includes - Front and Rear Bumper Brackets and Steering Adapter Notes -
Here is another 3" body lift kit from Zone Offroad Products but is for the gas engine.
Zone Offroad - Body Lifts - 99-03 Super Duty |
Body Lift=FAIL
Thanks guys, i didnt think there was anything out there but wanted to check just in case. I by no means want a body lift, i hate them more than i do ricer racers! Im just tryin to find a fix for my fender rub.
How about smaller tires?
Smaller Tires? Now what kind of red blooded american would want to go to a smaller tire? lol i know theres away for me to fix the problem but im trying to stay away from the "home made fix" if you know what i mean.
What size wheels do you have on the truck? Do you know the back spacing? Also, what brand lift kit was installed on the truck? You may be able to gain some lift with new shackles...
Originally Posted by Furian
(Post 8351601)
Pro Comp makes an 2" add-on kit for your 6.5" lift kit. It's Part# 52484B.
http://www.explorerprocomp.com/PDFs/07cat/28-43.pdf [LEFT]P/N 52484B [FONT=Helvetica-Condensed][SIZE=1][FONT=Helvetica-Condensed][SIZE=1]is available to increase the height of an existing Pro Comp 6.5” lift system. This package provides heavy duty 2” replacement front spring hangers, 2” extended length spring shackles, eccentric track bar adjustment hardware (keeps the axle centered under the truck), front driveshaft spacer, rear driveshaft carrier bearing drop bracket, longer sway bar links, longer ES9000 shock absorbers and all of the needed hardware. Both packages are available without shocks absorbers – request P/N 52484B-1 or 52482B-1 |
Darn... double post!
thanks a lot man!! that really helps...now the problem is passing that by the wife aka banker!:-X02
Originally Posted by jboy32
(Post 8353244)
