98 expedtion key replacment
lost my keys completely
how should I replace I thought about a screwdriver but remembered there is a chip locksmith says he can put one in for 200 is there a way to drive this with bypassing the ignition ? |
Originally Posted by mrbigmark
(Post 8316846)
the dealer I would think would charge a lot more than the locksmith ,?
(Post 8317433)
Call the dealer and ask them. |
dealer can't make a key unless you have the key code. ford codes only go back 10 years. they can make one up and put in a new key cylinder but then your key won't work your doors.
can a key be made from the vin # ?
NO KEY CODES LOOK UP ONLY GO BACK 10 YEARS
thanks
I guess its the locksmith for the ignition hopefully that comes with a keyfob . a new key fob should work ? also when changing the ignition what do I have to do to get it to work ? would it need to be reprogrammed ? |
yes it will need reprogramed. the locksmith might be able to do that.
If you have comprenhensive insurance, lock-out service and new keys will be provided by them, it's what you are paying for.
Also, Pop A Lock service will do it for about $125.00 for both keys. |
I have full coverage ,I dont know if comp is included in that
I thought I would have to pay a 500 deductible . any way I just got done paying a locksmith 220 for one ignition key and one door key ? now I have no key fob .but at least I can drive . |
(Post 8319575)
