Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum28/)
-   -   Please help confirm towing capacity (https://www.ford-trucks.com/forums/908038-please-help-confirm-towing-capacity.html)
twinpeaks 12-04-2009 09:32 PM
Hey...
I just want to make sure I am correct about the towing capacity of my truck....
I believe it is 7,500 but better safe than sorry...
Would someone mind confirming this for me so I don't screw something up
Thanks
http://farm3.static.flickr.com/2542/...3957acebd5.jpg
A1C DiMaggio 12-05-2009 12:28 AM
need to know year, engine, and if you have modified it at all
twinpeaks 12-05-2009 12:37 AM
'93, 302v8, no mods at all....
2wd, regular cab
A1C DiMaggio 12-05-2009 12:57 AM
i know the towing capacity for my 300 I6 is about 7500 with a frame mounted hitch. so i figure the 302 has about the same torque specs, little bit higher hp, and weighs about the same, so 7500 should be alright. i would take it easy though, the truck aint exactly brand new ya know
Robertlog 12-06-2009 01:42 PM
7200 lbs with trailer towing package, according to this website:<P>
Camping Life Magazine
Conanski 12-06-2009 01:53 PM
According to my owners manual the max combined weight raiting(GCWR) of truck and trailer for the 302 with 3.55 gears and auto trans is 11,500lbs, so subtract your loaded truck weight from that and you'll have the max trailer weight. A 2wd reg cab probably weighs 4500lbs with a full tank of gas and driver so that leaves 7000lb for the trailer. This is of course for a brand new truck so you should derate that for age and overall condition of the vehicle, personally I think 5000lb is probably the safe limit for a 20 year old truck in top shape.
andyman7931 12-06-2009 07:29 PM
What are your plans for towing? If you're towing close to the limit with the truck, plan on installing an aftermarket trans cooler. Also I don't think you should tow in OD on the E4OD
twinpeaks 12-06-2009 07:42 PM
I will be towing a 20' featherlite dual axle (approx weight 2800lb) with between 1000 and 1250lb of gear.... Racing go karts.....Tools...... Etc
The trailer is 8' wide and has a 7.5 foot ceiling height so I figured I should also factor in for poor aerodynamics....Saving grace is that it has a v nose
I just want to make sure I don't need to make any mods such as a tranny cooler or stiffer springs
I estimated that if I stayed around 4000lb (+/- a couple of hundred) I should be fine....
Also, from what I understood, you should never tow with OD on..... Is this true?
Better safe than sorry
Thanks for all of your input
rikard 12-06-2009 08:36 PM
Your truck should have no problems hauling that trailer. An aux tranny and/or engine oil cooler is nice but not necessary unless a lot of your towing will be all stop and go. I have put a tranny cooler on all of my automatic tow vehicles, cheap insurance.
regards
rikard
1OldFordMan 12-06-2009 09:26 PM
Sounds like 4,000 should be safe. Here's a discussion about towing w/OD.
https://www.ford-trucks.com/forums/907915-over-drive-questions-in-re-guards-to-towing.html
