Over-drive questions in re-guards to towing
Hey fellas. I have my own towing question. I might be using the old Ford to tow a relatively light load this weekend. I'm going to Ohio to pick up some things.
I know Ford says we shouldn't tow in Over-drive. Is there a weight limit to go by, as in, If the load is light enough could I keep my truck in Over-drive? I would really prefer this. I will get you guys real weight numbers here in a little bit as to what I'll be towing. My truck is geared low and I would hate to drive the 4 hours with my engine singing at 3,000 rpm at 55 mph. That's sucking down a lot of fuel for going so slow. Is it okay to kick the truck into OD on flat ground? If I see a hill or mountain coming up, I can manually kick it out of OD. Would this be advisable? By the way, I know if I put taller tires on the back I would effectively help lower my highway rpm's but I just can't afford that right now. Thanks folks. Any info is good info! I'll try and lookup how much the trailer will weigh |
honestly i wouldnt advise it at all i have the same option on all that and when i tow even something small i turn off my od
I use OD when I'm towing from time to time.. I usually figure if it will hole OD with the criuse set, its fine to be towing in that gear.. But IF your towing , say another pickup, or car I wouldnt. But something lite like a little camper or a couple atvs I would say its ok.. Just dont let it shift in and out alot.
Originally Posted by 6CylBill
(Post 8203298)
Okay thanks guys. Appreciate it. I think I'll try it in OD and see how it does. If the ole' girl kicks in and out of OD a lot I'll just keep her out of OD and suck it up.
I'd advise against it. I tried that the first time I towed with my truck and it ended up costing me $3300 for a tranny rebuild and a bus ride home for the family.
That's an E4OD in there, right? Yeah, you can tow in OD with it, the loads that will hurt your trans will make that small truck unstable and cause you to either slow down or lose control well before any trans damage occurs ;) Still, would be real nice if you got some external cooler for it... By the way I tow in OD every time, I only stay out of it on uphills (cause of no turbo) and downhills (cause 3rd gives me better engine braking) - on mostly level ground I go straight into OD, lock the converter, set the cruise, and enjoy my CDs while happily cruising along at 1900-2000 rpms (57-60 mph) :D
The E4OD is rated to tow in OD unlike the other autos, but I have towed plenty with my AOD trucks in OD with no ill effects though it was nothing bigger than a loaded dual snowmobile trailer or 20ft boat.
You can do
but watch rpm and listen if it surge like lock then out lock converter. Use cruise control I wouldn't dare to use if road is hill it will push more gas then it downshift. I drive 96 E350 van with 3.55. Must keep off overdrive because it get in overdrive at 45 mph mean we cruise at 45 so it shift like crazy so we turn off and leave until we reach 55 mph. |
My e4od shifts into od at 45 but at highway speeds it shouldnt be a problem having it in od
Originally Posted by darthice
(Post 8203518)
use your best judgement. if in doubt..... i recommend towing with o/d off even it means compromising fuel economy..... there is a better planet available made of steel..... |
ok listen to punisher he is a pro when it comes to trannys
o/d off. Like thePunisher says it make a big mess.
Yeah, it's an E4OD. Thanks for the replies everyone. =)
Looks like I won't be using this truck for the tow anyway. We just brought home a '98 Dodge Dakota 4x4 V6 magnum - we'll be using it for the tow job. I was disapointed at first but I think the load would be so light it wouldn't prove anything anyway. Alright I'm gone, thanks!! |
Well this is somewhat amusing. I was leary about introducing a Dodge into the family. It has low miles. It felt very solid.
However, it already has a problem. It does not blow any heat. It is Winter. It's cold. Looks like we might be taking the Ford afteral. |
