Front drive axle?
Would someone be kind enough to tell me what front drive axle(s), transfer case(s) were used in the F 600s? Late sixtys on. Thank you
They used both Eaton and Rockwell (now Meritor). Not sure about the transfer case but my guess would be New Process or Dana.
Front drive axle?
Thank you for your reply. Anyone suggest where I might search for more info.
My 79 has a rockwell fds 75 (standing for 7500 pound) it was used from the 60s through the 90s.. and a rockwell transfer case (I didnt pull the model number but its sitting on my shop bench so Ill try to remember to do so) with a clark 5 speed spec'd from the factory
now it has the rockwell with a later model eaton transmission it you are doing a conversion your options are limitless,, you can look at companies like Boyce Equipment.. I love the air shifts,,,, no transfer case lever sticking up through the floor.. but you need air obviously notme |
front drive axle?
Thank you, After reading your posts about your projects i,m in awe, and also very envious. Fantastic project, picts, and up dates. I did some more research with your suggestions and opened the door to more dreaming. Thanks again.
Originally Posted by hypprotux
(Post 8212424)
<!-- message --> Heard constant whining sound from front drive .Didn't figure it out until taking off the Front Intermediate Shaft Housing ,grease was filled with metal .Bearing gobbled up the Clutch Sleeve on the oil pan side, bearing is in tiny fragments mixed with grease .Inward side Front Wheel Drive Shaft Housing is wasted .So getting parts on 2002 awd Bravada is one problem? But when reassembly ,what type of grease to use? For future Maintance is the rubber plug for greasing in the housing.
:-bigparty__________________ La mutuelle familiale de France Devis mutuelle familiale des cheminots fr HEAVY DUTY FORD spoken here.... Job Rated Stuff.. Our front axles weigh as much as your truck |
Originally Posted by oldbrokecowboy
(Post 8202414)
There is no Tranfer Case listed for any 1964/69 F600 4WD's. I read somewhere that all of these were converted to 4WD by Marmon-Herrington. The only Front Driving Axle listed in this catalog is also...only for 1971/72 F600 4WD's: Rockwell-Timken Model FDS-75-HD-X-1.
So getting parts on 2002 awd Bravada...
Oldsmobile: 1897/1908: Olds Motor Works / 1908/2003: GM brand. Billy Durant founded GM by purchasing Buick in 1906, purchased Oldsmobile in 1908, Cadillac in 1909. Y'all know...of course...that Henry Ford walked away from the original FoMoCo in 1902 after arguing with his financial backers. After Ford left, the financial backers brought in Henry Martyn Leland from Browne & Sharp (prior to B&S, he was a PE with The Colt Pat'd Firearms Manufacturing Co.) as their new Prez and Chief Engineer. The first thing Leland did was change the company's name, naming it after the French explorer and founder of Detroit: Walter de la Motte CADILLAC. In 1916, Leland left Cadillac, started a new company to manufacture Liberty V12 aircraft engines for the war effort. Leland named his new company after his favorite President: Abraham LINCOLN. In 1922, Lincoln went bankrupt after producing their first...and only car in 1921...which was an engineering marvel, but a styling disaster. The US Bankruptcy Court put Lincoln up for auction. The only bidder was...Henry Ford. |
(Post 8231384)
The only Transfer Case listed (in the 1964/72 Ford Truck Parts Catalog) is for 1971/72 F600 4WD's = Rockwell-Timken Model 5-29025.
There is no Tranfer Case listed for any 1964/69 F600 4WD's. I read somewhere that all of these were converted to 4WD by Marmon-Herrington. The only Front Driving Axle listed in this catalog is also...only for 1971/72 F600 4WD's: Rockwell-Timken Model FDS-75-HD-X-1. this setup is exactly what my 79 has |
Originally Posted by Notmeofficer
(Post 8212659)
Partner.. Not to be rude to you ,,,Not only are you in the wrong post but you arent even in the right forum
There is an excellent utube video on rebuilding the FDS 7500 pound axle,,, it has two parts
Here's the link for part two.. part one is in the margin.... it shows you just how large the axle is and some of the differences between it and the military top loading rockwells http://www.youtube.com/watch?v=qaOOtIO7e7 Number Dummy.. thank you for the informative post about bravadas.... :-).. you are the go to guy for car info.... |
