1978 F250 Weight
I've got a 1978 F250 regular cab, long box 4x4, 351 and I need to haul it to a different state. I need to know how much it weighs so I can size a trailer to rent.
I've searched this forum and found some info on 1978 F150s, and it was reported to be about ~4000lbs. How much more would a F250 weigh? I need to know how much the F250 weighs, but unfortunately the truck isn't running to take it to a scale. Any ideas or help would be appreciated! Thanks! Phil |
ive seen this posted several times. im pretty sure the general ruling was around 5800lbs. not sure, but i know ive seen it on here before.
Yup, 5800lbs is about right. Definitelly under 6000, unloaded.
I've used a 5000# capacity trailer before to move F250s arround. The only problem was the trailer sides were too narrow and even with skinny tires it just barelly fit. |
I weighed my 78 F250 4x4 400 long bed reg cab the other day, I was getting a load of rock. With no occupants and a 3/4 tank of gas it was 5430. I have a truck box too filled with heavy stuff. Also, 35 tires and a spare.
how about an f150 4x4 without the engine transmission and transfer case? how wide does the trailer need to be?
Mine is right around 5000.
