1954 F100 Heater Box
Does anyone know if the box from a 1956 F100 will fit in a 1954?
Are heater boxes from 1953-1956 all the same? |
1 Attachment(s)
They were generally the same and the 56 heater should fit in the 54. Remember though that the motor in the 53-55 are 6 volt and the motor in the 56 is 12 volt (but you are probably on board with that already).
Remember also that there were two types of heaters - Fresh Aire and Hot Water. The Fresh Aire heater was ducted to the outside by a louvered vent on the cowl side in the Effies an dhas 4 controls. The hot water heater is all internal and has only two controls. Here's the Magic Aire! Attachment 18911 |
Hello,
The defroster hoses are a different size. I just went through the same thing looking for one for my 56. The plenums will not interchange either. I have one from a 53 if you're interested. Ron |
Here is a stupid question...... How do you know which heater you have ??? When I got my truck it had nothing ..... Just holes in the firewall where it once was ..... Any help appreciated !!!!
If the passenger kick panel has a duct sized hole in it, you have a Fresh Air - if not, it is a recirculating version.
Originally Posted by FortyNiner
(Post 14875549)
Originally Posted by Julies Cool F1
(Post 8148576)
They were generally the same and the 56 heater should fit in the 54. Remember though that the motor in the 53-55 are 6 volt and the motor in the 56 is 12 volt (but you are probably on board with that already). Remember also that there were two types of heaters - Fresh Aire and Hot Water. The Fresh Aire heater was ducted to the outside by a louvered vent on the cowl side in the Effies an dhas 4 controls. The hot water heater is all internal and has only two controls. Here's the Magic Aire!
Originally Posted by Pappys53
(Post 20769311)
i has justcame across this post. I need to know where the hoses connect to the engine. I am working on a 53
One end to the intake, one to the water pump. There are other configurations but this is one of the most common without AC. https://cimg5.ibsrv.net/gimg/www.for...cb18dd0cc9.jpg Here is one in a '53 F-100 with the alternator on the starboard side. https://cimg6.ibsrv.net/gimg/www.for...6024f04fb6.jpg What's up with that paint scheme? |
