Ford Truck Enthusiasts Forums
-   Large Truck (https://www.ford-trucks.com/forums/forum232/)
-   -   Ford COE 196? Y-Block (https://www.ford-trucks.com/forums/902422-ford-coe-196-y-block.html)
4tl8ford 11-15-2009 05:43 PM
I found a pile of Big 60's (F-6/7?) Ford COE, What is left of cab is collapesed over/around Y-Block (Rams Horn's).
Did they use the Lincoln Engines in this well defined Truck?
rb48f6 11-19-2009 11:52 AM
3 Attachment(s)
Dick~
Ford did use a truck-ized version of the Lincoln Y-Block available in C-750, C-800 and C-900 models thru 1963. (Looks like the C850's came with the Super Duty engines.) The engines came in 279 and 317 from 53-55 and 302 and 332 from 56-63. A quick way to distinguish the larger Y-block is with the bolt pattern on the ram horm exh. The smaller Y-blocks were in a single plane. On the larger ones the outer most bolts on each end were canted up a bit. Also, on the larger Y-blocks the valve covers had more pronounced ridges at the bolt location. Pics below:
rb48f6 11-21-2009 08:42 AM
Forgot to mention the pics are of a '62 332 out of a 750 Series.
4tl8ford 11-21-2009 01:41 PM
I've tried to reply to thank you for the pics and info - just what I needed - FTE won't play
rb48f6 11-21-2009 08:25 PM
No problem Dick, and glad I could help. I've been having issues with the site since I got back last week. Keeps hanging up mid post. I finally got smart and copied verbage before posting. 'was getting tired of re-typing my posts!
