2005 4.6 2 valve in a 68 F100
Hello all I am new to this forum of the Modular Ford V8s. I am trying a project of putting a newer motor in an older truck. I have all wiring harnesses inside the engine compartment including the stock computer. I am however new to making a computer driven motor fire up. I know I could buy an after market computer and wiring harness but would like to save that money for other things on this project. I have a wiring diagram on order for this motor but would like to know what sensors does this motor need to have to opperate properly and what can I omit? Also any other tips you guys might have on how to make this baby fire up would be helpfull.
http://i70.photobucket.com/albums/i1...r/100_1203.jpg SS |
Well, these require pretty much all of the sensors to run properly. The PCM uses inputs from all of them. You do have the instrument cluster too don't you? I'm pretty sure it is required to release the PATS system and allow the PCM to let the engine run.
Originally Posted by LxMan1
(Post 8017953)
Well, these require pretty much all od the sensors to run properly. The PCM uses inputs from all of them. You do have the instrument cluster too don't you? I'm pretty sure it is required to release the PATS system and allow the PCM to let the engine run.
Originally Posted by Shoestring
(Post 8018368)
Hmm I have access to the cluster but I did not pull the system from the car. What is the PATS system?
Passive Anti Theft System It marries the cluster, key, and the PCM to each other. If all three do not match, then the PCM will not allow the engine to start. Aftermarket tuning can disable this "feature", allowing startup without the original cluster or key being present. JL |
Originally Posted by Johnny Langton
(Post 8020376)
PATS
double post
(Post 8021269)
Had not thought about the need for a tuning device prior to being able to start the motor. What tuners work best with these motors or does it matter? Are these chips or a programmer that you have to purchase?
I see you're in Texas by your profile-whereabouts are you at? JL |
I am in Amarillo. So visiting a custom programmer could fix what problems I might run into? Yes I am using or plan on using the donor vehicle transmission. It is supposed to be a good one.
(Post 8021734)
JL |
(Post 8022573)
A custom program will fix most of the issues in the PCM,but you'll still need to do some wiring,etc....I'll see who I know of that's reliable and close to your location if you'd like,and get you their contact info.
JL |
I'm new here & I'm right behind you! I was about to buy a wrecked cruiser at auction today, but let it go because after spending hours searching the net for info on getting the 4.6 2v to run in the truck, I was left thinking it was going to cost over $1200 bucks - and I still had to pull the entire harness out & send it to them (doesn't sound like much fun in a twisted wreck!). I should've checked here first! Have you had any luck yet?
Originally Posted by Rusty 63
(Post 8115167)
SS |
Have you guys and gals seen this truck being built and posted by Classic Trucks Magazine? A link to it is here. It is pretty close to what I am doing except they are using after market harness and computer with tuner. I am wondering how they did the fuel system and if there is a link to that part of the build. I have looked and have not found it. They are pretty good on other parts of the story but have left the fuel delivery part out.
SS |
Edelbrock makes a carb conversion intake. Ford Power Parts, I think. A couple of others too.
Ignition systems; Edelbrock, MSD, and Painless - I think. I've got a 71 F-100, I've been watching these threads getting ideas.. |
(Post 8125056)
SS Found it - June '08 issue (oddly the month you joined FTE) pg 60-69 of CT has the details - Grant used a custom tank from Rick's and an Aeromotive pump & stuff. the Title of the article is "Building an EFI Fuel System". I actually subscribed to CT when I happened to grab a newsstand copy & saw they were going to be building a truck close enough to mine (my rusty '63) to inspire me to get back into the garage. So in a really round-about kinda way, it's their fault I'm here! Thanks! |
