So, Im going to be putting 79 F250 Axles in my 92 F150. After this is all said and done I was wondering what category I would look under for getting a lift kit for my truck. Would I look under 79 F250? or say 92 F350?
Originally Posted by _Hilljack_
(Post 12334287)
go back to skool with your daughter meathead.
92-79= 13. 1/2 of 13 is 6.5 79+ 6.5= 85.5 so he needs lift kit parts for a 85 1/2 f-150 and a half :D |
Are coilovers segregated by year?
only in the southern states.
(Post 12334287)
Originally Posted by captain p4
(Post 12336003)
Are you retaining coils and radius arms or are you swapping the leaf springs from the 79 in as well?
Look at my sassy thread. Its a GED level how to
Use 79 suspension components |
Wow! That was a great thread and I will probably follow it carefully. So are you saying that I should do coils? Or should i use the 250's leaf springs. From the research ive done most people prefer coils up front vs. leaf springs because the ride is smoother. And also my dad was telling me that i shouldn't use 250 axles because then my truck will be 8 lug instead of 5. What do yall think?
A 44 is a 44 is a 44. Doesnt matter 5 or 8 lugs the strength is exactly the same.
A 9" is basically the same in the strength department as a 60 rear so it would be a matter of preference and what matching set of axles you find...be it 5 or 8 lug. It would be easier to use coils with a 5lug 44 front from a 73-79 150 but nothing wrong with leafs up front if you found a 44hd or 60 and matching 8 lug rear |
Well i just talked to the guy selling the 79 and he won't move on the price so its back to square one trying to find one :/
Find a 85.5-97 F350. Cheaper, and good axles under them.....
What is the length of your track bar mount from frame to the hole?
Originally Posted by ManfredVonRichtofen
(Post 12339589)
What is the length of your track bar mount from frame to the hoe?
Originally Posted by fatdan460
(Post 12339601)
depends whether paul is in the stg or joppa }>
