ODB 11 code P401
I have a 96 Ford Explorer with a 6 cyl. 4 L engine. I have a had a problem with the check engine light. My code scanner indicates P0401 and P0402 codes. I checked the EGR valve and took it off to clean it, appears OK. It will hold 5 in. of vacuum. I checked the vacuum from the engine to the EGR vacuum regulator. I get 22 in of vacuum to the regulator but nothing after the regulator. I replaced the EGR vacuum regulator but still get the P0401 code. I check the harness side of the EGR vacuum regulator with the switch on (engine not running) and get 11.5 volts, not the 4-6 v indicated in the manual. I also checked the harness side of the DFPE sensor and get 5 volts running cold, not the .35-.8 volts indicated in the manual. Is this a problem with the DFPE or PCM or something else?
ODB 11 code P401
You might want to post this question in the explorer forum this area is for the picture gallery and avatar image questions.
Wiz:-X03 An Equal Opportunity Truck Lover! |
ODB 11 code P401
